Fog light mod (Alternate version)
In my opinion, I don't see myself using the fogs w/o the parking lights. When I go out to move my car at night, w/ my old car I would just turn on the parking lights then the fogs...so how would I do this? Sorry if I've missed anything..too many posts to read through.
this mod still allows you to use the fogs with parks if you want...i like the fogs alone for a daytime running light setup...the hid fogs and low position of the lights give the car a nice look coming down the road. There is the older version that required use of the park lights to use the fogs without headlights, but this version is much better.
so why would it be so hard to jus flick on the parking lights when u turn the car on?...i did the new mod and i leave the fog button on so when i turn my car on they turn on instantly and if i have to i jus turn my parking lights on too...but like Uncle Jitty said, it looks sweet with jus the fogs on and no other lights on..i had my cousin drive my car around the block so i can see how my car looks and i wet my pants..
Second, I often forget to turn the fog light switch off and when I lock and unlock my doors the dam fogs blink on and off. And since I have HID's thas unnecesary wear on the Ballast. So this mod would eliminate that problem too. To me its, the way to go!! Good Job Bxscig!!
So let me double check this, I mean no offence. I too added HID's to my fogs and I keep forgetting to turn them off. I'm afraid it'll burn out my ballasts. So with this mod, I can leave the fog switch (and the headlight switch too) in the on position...and use my remote to (un)lock the doors and not have the fogs turn on/off w/ the rest of the lights? I like having my headlights turn on at night when I go to the car....
NEVER!!!..:devilgrin...i park my car in front of my job so everytime i look out the window i see this beautiful 03 AM jus staring at me...
be carefule with that bro...ur putting strees on the ballast and then all of a sudden...
..bye bye to the ballast...
that's how i roll - not because i saw the rdx, but because it looks mean. i have 3000K hids in the fogs and it looks very mean imo. if my car is on, so are my fogs no matter day or night.
Even with the alternate mod completed? Oh, btw I picked up the ATM Add a circuit and noticed they don't carry diodes. Guess I'll have to wait til tomorrow and try Radio Shack.
I also roll w/ my fogs on almost 24/7...mainly when I have my daughter in the car. I'm thinking of getting 6000k bulbs for non-rainy/messed up weather conditions...
Ok, ran into a problem...now my SRS and CEL lights are on. There's an OBD2 reader at work and I could easily clear that tomorrow during my next shift. The SRS is what's going to bother me...I unplugged the fuse, put the fuse (for the added circuit) with the HHH (add a circuit) like the instructions said. Put the key in and pressed the fog switch. Nothing. So I swapped spots on the HHH for the fog mod. Still nothing, with thhe exception of the D5 light flashing at me. I then put both fuses into the HHH and the fog mod works fine and the D5 light doesn't flash at me anymore, but now those SRS and CEL lights are on.....is there a way to clear the SRS light w/o a computer?
u mustve turned on the car without everything connected...i did the same thing...here u go...thanx to Kris i held on to this jus in case...
http://www.geocities.com/myintegra96/srs.html
Just got done resetting the SRS light. Thank you so much for that link! It took 5 tries before I did this:
Took a REALLY long speaker wire and stripping the insulation on both ends. Then from the comfort of the driver's seat I did it in the first shot.
Times like this I wish I had a momentary push button "tool" to make it easier...plus have it long enough where I'm not looking up and down (between looking for the flashing light AND pushing the clip back into the connector "properly" so it takes it.
Rich
I want to do the same to my wifes 03 tl??????where do i find these two wires? under the hood or under the steering wheel ? do they work and turn off and do not flash when you lock the car with fob? how about if i ask one mmore question? how do i replace the led on the fog lite switch/
thanks and let me know what ever will help me do the car
Is this country great or what
sonny in san antonio
Rich
Rich
https://acurazine.com/forums/showpos...8&postcount=32
Rich
the two wires ur talking about are right behind the the actual fog siwtch...really easy to get to...the newer fog mod doesnt flash with the parking lights...with the new mod u can leave the fog switch on and they turn on without having to have the parking lights on which IMO looks nice...i have HID in my fogs so if i were to do the older mod and forget to turn the switch off i wouldve at some point blown my ballast when i would arm/disarm my alarm...heres a pic of mine with the newest fog mod...
I just replaced my 03 tL headlite assembles and also install the new sylvania HID (137 each) thru Advance Auto.....they look great especiall with the almost new glass on the headlites but ..................
I now want to do what you have helped others do???????if I start this project could I count on you answering some questions before and during the project??/
God Bless And Thanks
Is This Country Great or What
Sonny
Sonny
^wow u got raped on the bulbs for 137 each but if u got them then u got them already....couldve gone with our vendor Excelerate for 109 for both bulbs shipped....but on to the fog mod....look closely at the pix and the Diode(part) becuz when u go to radio shack they have a shit load of them
mod complete!!! the splice didn't work, I had to peel away the insulator and wrap the wire around that and tape it until I get the right splice tape will work!! Other than than great mod took me a bit longer cause I really don't know how to use a solder gun. Today was a crash course in how to's.......LMAO Thanks for an awesome mod will post pics ASAP
Hello everyone. I did this mod to my TL but without the add it circuit. I spliced a wire going to the fuse box (2nd to last on the right side) I think it was a yellow wire. The first time I connected the wire directly to the white wire on the Fog light switch and turn on my headlights all the lights on the dash use to turn on and act like the keys were in the car. I connected the diode to only allow the electrical current to flow to the fog light switch and not from it.
It's working perfectly fine here, only turns on when the key is in the ignition, and/or when the headlights are on. my question to you guys is. What is the benefit of having the add-it-circuit? can I encounter any problems later on by connecting it the way I did?
Thanks for your help.
BTW: This is my first post, I just got my 2g TL about 2 weeks ago and the posts on these forums are very helpful.
...welcome to the forums....and the best advantage of the add-a-circuit is that you dont need to have your parking lights on with the fogs....it looks hella nice that way especially near dawn....and the other thing this protects is in the event something goes wrong you have that extra fuse to protect any electrical problem if something goes out.
^^What he said. Fuses are ur friend when working with anything electrical in a car. Its mostly just for safety. And for $10 total for the mod..def worth it for me. But it's ur car so do what u want man..if it works for u and ur not scared anythin will short then leave it.
Hey Zues..how are those 5000k on output? I wanna go with the Phillips 85126+ and I've read they look like 5000k...I like the stock output and don't wanna lose light..even tho I have already cuz of the age of my bulbs (stockies)
Thanks for the reply guys, I will put the fuse on it. I initially left it the way I did because I did it on the 4th of July and my local AutoZone closed early, I was only able to go to radioshack to get the diode, I didn't feel like waiting to get the mod done
You'll grow out of it
