Floor Jack Lifting Points
Old Sep 21, 2008 | 04:57 PM
MikePA's Avatar
My floor jack has the typical shallow cup on the lifting end. Should I just place this under the lifting points where you put the jack that comes with the car or is there a better location?
Old Sep 21, 2008 | 05:44 PM
Rajca's Avatar
wham bam thank you ma'am
i put it under the lifting points (3" wide tab that sticks out)
Old Sep 21, 2008 | 06:11 PM
Stimpy's Avatar
i have a cup too. when i wanna do the front i cup the hump that sticks down right in the center line. rear is similar on the frame.
Old Sep 21, 2008 | 06:31 PM
FirePR2002's Avatar
bringin lead
i sometimes use the tow hooks on the front or back, other times i use the side lifting points - depends on what i'm doing. the rear is so light you can pick up both tires with the tow hook.
Old Sep 21, 2008 | 06:42 PM
Rajca's Avatar
never thought of using the tow hooks, gonna do that now, sounds easier to put jacks under the car.
Old Sep 21, 2008 | 07:00 PM
MikePA's Avatar
The TL is a unibody car. Where's the frame?
Old Sep 21, 2008 | 07:36 PM
Mista Juice's Avatar
i use the tow hooks to jack the car up and the jack points on the sides of the car for the jack stands..
Old Sep 21, 2008 | 08:04 PM
jayunsplanet's Avatar
2 of my jack points are bent over flat. Have to use wood to have the jack clear my sideskirt. But yes, I use my jackpoints for lifting.
Old Sep 21, 2008 | 09:06 PM
fsttyms1's Avatar
Get a jack with a larger lift pad (if its not the 4")
Use the lift points, the tow hooks, I personally use the front center lift point to lift the whole front evenly at once. The rear tow hook as well, that leaves the factory lift points for the jack stands.
Old Sep 22, 2008 | 08:47 PM
my passenger side front is bent ALMOST over flat.. it was like that when i got the car.. sucks that the car sits lop sided when working on it.. ugh..
Old Sep 22, 2008 | 09:24 PM
AMGala's Avatar
Lamborghini Aventador FTW
For you guys with bent jacking points, if you can get your car up on a lift you can try to bend them back to the correct position
Mike734
Dec 10, 2021 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
JDM96specCTR
Oct 17, 2015 01:06 PM
navtool.com
Sep 25, 2015 05:15 PM
