Is this the first sign of tranny problems
Just wondering if anyone else has experienced this. Recently on startup after the car has been parked overnight. I drive about a block or so and make a turn. Part way into the turn when I step on the gas the engine just revs as if the tranny was in neutral. I wait a few seconds and it goes again with no issues. The first time I thought it had just slipped into neutral, but it has happen twice more. I am going to try giving it a few extra minutes to warm up after extended parking periods to see if it makes a difference as the car runs normal after the initial incident each time. There were no abnormal indicators lite on in the dash. Everything felt and sounded normal.
02 tls with 76,000 km - oiljet installed at 56,000 km
05 C230K & 09 135i 6MT
Yes, that's slippage. transmission.
Warming it up further won't do anything. The transmission fluid will be cold as long as the car doesn't move, even if it idles for an hour. But this is a dying transmission - not cold weather, cold fluid, or anything else.
My transmission doesn't go as far as feeling like it is running in neutral but the car does seem to hiccup now and then (the acceleration isn't completly smooth starting off) but there is power the whole time. Does that sound like transmission slippage to those who are more familar with it than me or could it be the injectors? Did yours do this before it got where it is now Ratchet?
My car did what your's was doing, Lyle.
I took it for inspection (it was still driving fine, just having some hiccups) and they inspected it and when I got the invoice from the dealer it said:
"Transmission replaced due to internal failure."
Thanks for the info. I guess I should take it in before it goes on me at some random time. I was hesitant to get it looked at because it seems like the replacement transmissions are having more problems than the originals. I have a 2002 TL-P with 54K miles; oil jet installed last year under first owner (I guess that is about the mileage based on many of the threads I have read). Sounds like mine will go sooner or later though no matter what so may as well be on my terms.
How has the new one been working out? The shuddering is probably the best way to describe it, mine is doing exactly that. It seems to be completely random so hopefully it won't be difficult getting the dealership to replace the transmission. It sounds like your dealership checked it out thoroughly as opposed to just driving it so I'll probably be fine as long as they do the same.
Well when mine went in they found it had both front and side motor mounts broken and they replaced them (warranty). The shudder continued (and not every time, sorta random) and so they replaced the transmission AND PCM.
The shifts come sooner than they used to at WOT, and for the first few days I was sure they deducted 30hp or so. After getting used to the new feel of the transmission (shifts are undetectable, sort of like my 05 AV6 with drive-by-wire) I don't think the car is any slower. It feels new again.
It might be. I have had 3 transmissions. On my most recent one. I did not drive it for 4 days soon after it was replaced. And it did the same thing, slipped and then caught.
I took it in and they could not replicate. I have put 12K miles on it now and no more slip.
But considering the mileage..... it very well could be.
On the way!
My tranny (the 3rd) also had a shudder on the 1->2 shift from the time I picked it up. I did the change to Amsoil and after running it for a while it's smooth as silk.
I would advise anyone who is switching to amsoil to not just do a drain and fill. My shifts were affected (were quite harder) with only one drain/fill of amsoil.
My tranny now has actually had 4 drain/fills (one 12k ago, the rest 2k ago) and it's running like new (or better). Fluid is perfectly pink.
I'm not convinced that my dealer is actually using Honda fluid. Shuddering on shifts after a rebuild is usually a sign of the wrong fluid...
Originally Posted by fla-tls
Lyle, that could be any number of things. Don't blame the tranny yet.
thats interesting..I thought the tranny was past repair when you start feeling the shudder. Im not gonna take any chances with mine though, Im taking it to the dealer to get it serviced. Why not? Its FREE!!!
On the way!
Originally Posted by fsttyms1
And for the people here what is the specific amsoil tranny fluid you used
Before I sold my 2002 TLS, I only had 6000 miles on the car and the tranny fluid was brown. I haver had any problems but I dumped the car and purchased a '04 6mt before the tranny died. It was a tranny just waiting to fail. The new owner is still running the orignal tranny, but I'm sure it's going to eventually fail. I'm just glad he's got the car now and it's not my problem anymore.
Interesting, I was thinking of replacing the transmission fluid soon (only thing left to change since I bought the car 2 months ago). I also live in Orlando, which dealer do you usually go to fla-tls?
Just changed the fluid today (3 times drain and fill with Honda fluid). I have only driven it the few minute intervals between the changes, but it already feels much smoother driving and with regards to engaging the shifter. The trans better last me a while with my $50 bucks of Honda fluid used in total So far so good.
On the way!
I do it myself (with regard to transmission fluid).
Thanks, yeah I changed it myself today. Very easy DIY but took me a while with doing 3 drain and fills. I was wondering more for later on if I have to take it in for transmission inspection. Seems to have smoothed it completely out with the new fluid. The first drain was completely black and a ton of stuff on the magnet drain plug. 54K miles and I don't believe it was changed ever based on the condition of the fluid and the drain plug looked untouched. It was easy to remove both bolts using a breaker bar and 12" extension as has been noted. The right tools make all the difference!
On the way!
...The first drain was completely black and a ton of stuff on the magnet drain plug. 54K miles and I don't believe it was changed ever
Sorry - but that's a very bad sign. Thank God for warranties!
On the way!
I need to take it in and get it checked probably, of course now there aren't any signs of shudder, slippage or indicator lights. Should I take it in just for inspection even with no noticeable signs when driving it?
When I first changed mine it looked the same as yours. It failed soon after I changed it. Your tranny will probably fail prior to the warranty end (15k more miles).
That is EXACTLY what happened to mine at 50k miles. First noticed it
exiting a highway ramp at a bridge. Left hand turn slightly uphill over
the bridge. 2-3 weeks of inreproducable intermittent 2nd-3rd gear
slips.
Once it became consistent it was a matter of about 50 miles till total
system failure. Abrupt shift to 2nd gear from 5th and dashboard lit up
all lights. Ver scary. I was actually on the wat to the dealer when it
failed.
Better make an appointment ASAP, especially when it slips consistenrly.
/Steve
slips.
failed.
/Steve
I am taking it in Sat for inspection. The symptons are subtle, but I am taking it on a 1500 mile trip soon and it won't hurt to have it looked at. I realize I won't be in 3rd gear for much of it. Talking to one of my coworkers who just had hers replaced it sounds like her service rep is really good, so it is worth the time for him to look at it probably just to be on the safe side.
Thanks for the info, that just confirms I should be taking it in. Mine hasn't got to the point where slippage happens consistently, but why wait. At least the dealers are well aware of the problem so you shouldn't have to prove it is having problems 100% of the time. Won't they inspect the clutch plate and doesn't that show early detection?
About all you can do is bring it up to the dealer that you have been noticing slipping between shifts and hope they see it on their test of it and decide to have it replaced. If not your stuck with it till it gets worse
Besides the tranny though, our cars (TLS) are mechanically great... right? I bought this car based on the HONDA durability record, which is impressive in most of their vehicles. bottom line is I really want this car to last 200K miles.
Yes the TL is a great car other than the tranny. Mine is nearing 200k and its just as good as the day i bought it (mechanically speaking)
They cant inspect the clutch packs with out taking the tranny out of the car ripping the tranny completly apart.
That is what I thought, but I could have sworn I read something in the recall notice where they mentioned checking it before installing the oil jet. Makes sense though, my mistake.
On the way!
My best advise - if you have black/burnt fluid, take it to the dealer and have them check it out. Black/burnt fluid is a sign of clutch slippage and should be grounds for a removal (certainly if they also find codes as well - remember some codes don't light the check engine light until they happen several times).
There's nothing that can burn fluid except for slippage or a loss of cooling (or a 600 degree design defect - but that's not normal - go figure...)
Originally Posted by 03CoupeV6
Lots of times changing fluid in a car that has never had it changed is worse for it than not changing it. Your transmission will probably soon fail, but you're a 2002 - you've got a few years left on warranty and 46,000 more miles.
Sorry to bump a very old thread, but it took me two years to put on over 20K miles since the first trans fluid change at 52K miles. I actually sold the car a couple months ago but the original trans still shifted beautifully at 71K miles. I miss the TL, even though I got a 10K mile 04 Corvette to replace it.
I'll probably have another TL at some point in the future.
hope you told the new ower about the extended warranty- the trans will probably go soon!
Course, I actually gave him the notification I was sent. It shifted smooth as silk still. I was paranoid when I first bought it after reading these threads, but after doing the change I couldn't believe how well it shifted. Still had two years and 38K miles on warranty when I sold it.
Good job!- most 2nd or 3rd owners have no idea about the warranty- some people even sell their TL thinking the trans is going- and not know about the freebie
Yeah, I probably should have kept it longer but I always wanted a Corvette. My TL was a great car, I kept it spotless and so to the first owner. Oh well, might pick up a 3rd Gen TL-S at some point in the future.
This community was a great help, I'll probably be back.
