Which filter is better?
Old Jan 26, 2001 | 12:07 PM
AcuraTL's Avatar
OG
Post
Weapon-R's filter is one of the best. It provides the best flow vs. even K&N and HKS's filters. Don't worry when it gets dirty, it is just trapping dirt.
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
Old Jan 26, 2001 | 12:28 PM
JYOO's Avatar
Post
I thought K&Ns flow the best??
Old Jan 26, 2001 | 12:54 PM
AcuraTL's Avatar
OG
Post
K&N traps the most dirt but they do not flow the best. A couple of year ago, Weapon-R did a flow bench test with Weapon-R filter, K&N and HKS. It said Weapon-R outflow the other two, I believe Weapon-R paid an independent tester to test it that's why K&N and HKS did not do a rebuttal test.
Old Jan 26, 2001 | 01:06 PM
yjack's Avatar
Post
Best filter is Apex power filter. It flows about 10% more than the K&N, and has best filtration rate. And it is dry type filter, so you do not need to mess up with the filter oil. The Test was done by Japan. I do not have the report, but someone post them before at SHO. Cost around 60-80$. The only problem is the filter do not fit the regular 2.5-3inche pipe. You need do some modification to make it fit.
The worst filter is the HKS. the worst flow rate + worst filtration rate + highest price.
Blitz filter is also have highest flow rate, but filtration rate is not as good as Apexi.
But because the filter is made by steel, so it will last forever.
The K&N is somewhere between those.
Old Jan 26, 2001 | 11:28 PM
JYOO's Avatar
Post Which filter is better?
I currently have a weapon-r intake with the funky foam sticky filter. It gets dirty too fast should i put a k&n in instead?
Old Jan 26, 2001 | 11:39 PM
fred3113's Avatar
Post
if you install a k&n, you will gain 5 horse!
2000 TL, Satin Silver, Burlwood shifter, Fog light ports, front air dam and mud gaurds custom painted to match car! 18" Alba Blaze with 235/40ZR18 Toyo Proxes F4
rcs86
Aug 2, 2016 06:52 PM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
steve
Sep 30, 2015 09:23 PM
jmaxima03
Sep 27, 2015 10:22 AM
