Filling trans with a oil jet kit installed
I have the oil jet kit on my transmission and I want to change the oil. Can I pull out the pipe in the center of the fill bolt and fill it there or will need to remove the fill bolt also? I assume I can just pull the pipe out after removing the bolt that holds it on.
All you need to do is remove the 1 bolt holding the oil jet in and pull the oil jet straight up and out. Dont worry, you wont mess it up or put it in wrong. it can only go in 1 way
Originally Posted by flydog
Or you can just fill it through the dipstick tube
Do I need a new gasket for the oil jet tube?
cycdaniel
12-17-2019 10:58 AM
IIDXholic
10-08-2015 07:53 AM
asahrts
09-04-2015 05:55 PM
nuldabz
09-03-2015 05:49 PM
