FAQ: 06-07 AV6 Transmission 'Swap'
Old 11-23-2018 | 03:23 PM
  #681
JaceOk's Avatar
7th Gear
02 CL AV6 Swap
I just completed this swap via precise directions found in these forums February 2017. Pretty much everything was exactly as detailed with the exception of the "cooler" on top of the trans. I only swapped the top part as the hoses didn't align. My fear now is in my possible misreading/understanding may be I should have changed more parts under it? It's currently November 2018 and the car has ran basically perfect until a month ago, started clunky shifting developing into trans slipping shortly failing after slippage. Everything worked great actually quite perfect and performing better beyond expactations to this point. I write this for the next guy that's gonna tackle it himself. Where did I go wrong with the swap a 114k mi 2006 av6 only to have it fail. Maybe just a rough salvage trans or did I misinterpret something and muck something up with the swap. Haven't seen much on longevity in reference so wondering where I fowled fellas....
Old 11-23-2018 | 03:27 PM
  #682
JaceOk's Avatar
7th Gear
02 CL AV6 Swap
Pardon my manners also but would like to thank everyone who's posted the swap details and needs that made it possible for me to make it happen in my driveway! The car gave me almost a year of excitement and fun while I'm only into it for a little over 1,200 car and trans/parts! You guys are awesome!!!
Old 02-08-2019 | 11:26 PM
  #683
Megglers's Avatar
I recently performed an AV^ swap back 09/2018. I had the trouble with the torque conver not being the correct size. I got a rebuilt converter from Transtar ( HO79 ) and installed it. Car worked perfectly to start but after a few days it started giving me the P0740/VCS/! lights. The torque converter that came with the trans was damaged internally due to an accident. So I assumed that the transmission must have been damaged as well. I drove the car for the last 5 months with the cel on and after driving about 25-30 miles the vcs/! light would come on. The car also was slow to got into gear when cold, but after about 3 seconds or a rap on the throttle it acted normally even if I shut if off again. If I let it sit for a few hours then slow engagement would return. I was coming up on my 6 month warranty and decided I had better get it swapped out. So now i have swapped out the transmission with another used transmission and the same lights and code are back. This time the lights come on much quicker than before. I also notice now that when the t/c locks up the rpm is much more stable than the other transmission ( hadn't noticed that ). I did not use the donor torque converter as I had a relatively fresh one. I am now wondering if the converter could be the issue? Any help/insight/diretion with this would be greatly appreciated.
Mike
Old 02-11-2019 | 12:00 PM
  #684
whitetiger5's Avatar
P0740-Problem in the lockup control
The service manual does a good job of helping with troubleshooting this:
  1. Check the pressure which that sensor is monitoring
    1. pressure good-replace the sensor
    2. pressure bad-some work to other parts of the lock up control
On the bright side: I didn't see anything in there about replacing a transmission, or torque converter. It sounds like you problems are elsewhere which may explain why the problem persists.
Old 02-17-2019 | 09:42 AM
  #685
pbeck66's Avatar
Hello, I am back. I replaced my 2003 tl with a 2007 AV6 (documented in pgs appox 13 of this forum). Worked great for 2 years until daughter just wrecked car. Bought another TL with the transmission issue (for practically nothing) and will be doing this transmission swap again. Getting more difficult to find the 2006-2007 AV6 from Accord. LKQ still has some but want $1,000 for it.
I have found some 2006-2007 Odyssey transmission for much less. I have re-read the forum but cannot find explicit answer of whether the Odyssey will work.
Skirmish, or others, will the Odyssey work or just pay up for the Accord?
Old 02-17-2019 | 10:07 AM
  #686
horseshoez's Avatar
Latent car nut
I am by no means an expert on this, but I believe 2007 Odyssey transmissions will not bolt up to a 2004-2006 TL engine; different mounting pattern. Regarding the 2005 and 2006 Odyssey transmissions, they may well bolt up, but I have never heard they were upgraded to the BAYA engineering build.
Old 02-17-2019 | 11:11 AM
  #687
pbeck66's Avatar
Got it, ok. Guess it better to stick with the higher priced accord V6. Thx
Old 02-18-2019 | 02:55 AM
  #688
TacoTom1967's Avatar
Originally Posted by Operationalist
Hey they007. Sorry for the late reply... Just wanted to notify you that I'm experiencing word-for-word the exact same symptoms that you are. I've managed to put another 10k or so on my trans in the meantime despite the lingering issues. The one drawback I've noticed is that my new trans gets a little lost looking for TC lockup/"5th gear" under WOT. But as long as I accelerate up to highway speed at ~75% throttle or lower everything seems to operate smoothly.
I also did a 3qt drain and fill very recently. Seems like I probably have a slow trans leak somewhere around the TC and bell housing, but besides that the fluid I drained was pretty clean and the drain magnet didn't seem overly gunked. I too am hesitant to drop a bunch of money on solenoids or harnesses without some certainty that it will resolve my problems.
TO ALL FUTURE AV6 SWAPPERS: Please take a measurement of your flexplate/torque converter diameter during your installation and post it in this thread (measure from center of bolt hole to opposite center of bolt hole). It could be invaluable info to those of us like they007 and myself to know if others are using the 10.75" flexplate/TC (e.g. Dacco HO18) as opposed to our 11.25" flexplate/TC (e.g. Dacco HO21). Also, a post-installation update describing whether or not you have experienced the same P0740 CEL and TCS / "!" light-up would be instructive as well. Thank you to anyone in advance who can help us out.
If it appears that others use a 10.75" flexplate/TC and do not experience the same problems, I'm inclined to crack mine open again and swap in a 10.75" setup before the end of this year.
Hello,
j know this is a thread for the 2g TL , but I’m doing this swap in a 3g TL. After pulling the trans I took the tc off of it I noticed what looks like a shim on the tc hub/shaft. I don’t have a micrometer but when I got a stiff piece of card stock it is obvious that the shim make the distance from there to the end of the hub is a the shims difference different. Has anyone seen this? My car is a 06 TL and the BAYA I pulled from a 07 Accord. As this is my only car, a timely response would be great. Thank you in advance.
Old 02-18-2019 | 05:23 PM
  #689
Part of a repair sleeve?
is it solid? perhaps it is the reinforcement in the TC mainshaft seal? what the condition of that seal?
Old 03-05-2019 | 07:54 AM
  #690
Abraham Shield's Avatar
Swap complete...
Thanks to all the great info here and the .pdf of swap info kindly created for those of us doing it a few years later than some, I just completed my AV6 swap into my 2003. Donor trans from an '06 AV6 Coupe with 90K miles.
No major issues, however getting the CV axles out of the trans can prove difficult particularly on the passenger side. Thankful for wobble extensions and air ratchets! I changed the engine rear main seal, both axle seals, and the torque converter seal while I was in there. Did the whole da%n job only to try and mount the torque converter to flex plate after tranny was in and all suspension was installed. WRONG effin' torque converter. I apparently ignored all the notes on here and ordered a converter from a BAYA which fits fine, but the bolt holes are about 1.5mm too far inset for the flex plate to mount. Soooo, I did the tranny job a second time. Total time involved (without the mixup) was about 9 hours, I could do another one right now in about 7 I would think.
Car drives like a dream, found out my original TL range position switch was toast on the tranny... hence my intermittent no-crank condition. Car did NOT know it was in park or neutral, so I replaced it with a new OE switch. Now I have full 5-gear operation, sport shift works great, and no more MIL light for violent shifting/shuddering issues. Thanks to all who have contributed, if you want to see the tranny removal in a much faster 30-second clip, click the link below for a time lapse.
Time Lapse TL Trans Removal
Old 03-05-2019 | 11:57 AM
  #691
I almost ended up doing the same. Luckily, I thought of matching up the flexplate to the torque converter when both were out of the car (when I was changing the rear main seal).
I still had an issue after bolting up the first hole on the flex plate, but it turned out that I was bolting up one of the wrong holes on the plate. I rotated the crank almost once more, took off the original bolt and started over...this time I started bolting the two together on a hole that is accompanied by some additional holes immediately adjacent (I believe for timing or balancing).
Old 03-05-2019 | 01:37 PM
  #692
I did it too. Not use to there being those extra hole on the plate. I turned the drive plate and TC until I could see two holes lined up and started the bolt in the one I could actually get too.
I did the AV6 swap into my 06 TL. I don’t know if the factory trans was that bad from the start(I’ve only had the car for about 46k of the 190k), but the difference is like night and day. The car would do 130 before, but that last 15mph took forever. Now at 130 it is still pulling hard. As I was pulling the trans I discover the drive plate was broken(I used the one from the Accord I was wise enough to grab out of the donor car) which explains why it sounded like the trans was locked up or in a bind. I swapped the trans as it was something I planned to do and the code I pulled from the trans said it was toast, but I can’t help but wonder if it is still good. As a stop or emergency backup.
Old 04-07-2019 | 12:27 PM
  #693
Is the BAYA in a V6 2003 Accord coupe the same as the V6 2006-07 Accord BAYA?
[QUOTE=whitetiger5;16384718]Part of a repair sleeve?
is it solid? perhaps it is the reinforcement in the TC mainshaft seal? what the condition of that seal?[/QUOTE
So here’s my question. What is the difference in a BAYA from 2003 Accord V6 coupe and the BAYA out of the 2006-7 V6 Accords? I’d love to know. If any body knows or can point me in the right direction to find this info I’d appreciate it.
Old 04-18-2019 | 10:43 PM
  #694
grayghost951's Avatar
[QUOTE=TacoTom1967;16408355]
The sleeve is from a shift/lube system improvement kit. The instructions say its purpose is to keep a case bearing from walking into the seal.
Old 06-14-2019 | 11:50 AM
  #695
MaxBeast4Z's Avatar
I am kind of new into this I want to know is there a specific av6 transmission I should stay away from from what to what year that I can take it from and is there anything in the transmission that I need to change that it will not work in the TL.
Old 06-14-2019 | 01:40 PM
  #696
Iggy's Avatar
did you read this thread? it's all here.
06-07 Accord BAYA trans.
Swap the trans harnesses
Old 10-27-2019 | 11:38 AM
  #697
Miller335's Avatar
Thanks for everyone's effort in this.
Anyone have the part # for the torque converter seal?
Old 10-28-2019 | 01:55 PM
  #698
Well being that you are using the torque converter from the Accord, I would imagine getting the seal for that specific car's TC?
Old 10-30-2019 | 08:25 PM
  #699
GRWeldon's Avatar
I would normally start a new thread, but I don't yet meet the requirements. I think this is only my 2nd post. Been lurking here without registering for years.
So I just bought an AV6 from a 2006 Acord 3.0 V6 from pull-a-part. I couldn't beat the price...$120. That's what they charge for all of their V6 front-wheel drive trannys. There is a caveat though...I have no idea how many miles are on the Accord transmission.
I haven't pulled the TC yet to inspect the oil, but judging by the car which appeared to have been beaten to hell, I'd guess the fluid is dark. I suppose I should replace the solenoids and pressure switches and I certainly am going to use a NEW torque converter. I'm wondering if anybody thinks I should open the case and check for burnt clutch sludge before swapping it in? I've never rebuilt a tranny before but I wouldn't hesitate to crack the cover open and check.
I don't know about the robustness of the AV6 so I don't know if a fluid and filter change would be sufficient after replacement of parts mentioned previously. I'm wondering what popular opinion thinks is prudent. Please advise!
Old 10-31-2019 | 03:00 PM
  #700
Do everything you can with exception of taking it apart or flushing it. I've seen some clean / replace the shift and pressure switches for peace of mind, but others have seen many miles from AV6's having 100K+ miles with a simple 3 x 3 fluid / filter change.
Old 10-31-2019 | 08:28 PM
  #701
Iggy's Avatar
^^ I agree. Tearing one of these apart is an invitation for disaster. Get new fluid/filter in and see how it operates. I wouldn't even bother with solenoids, they are easy enough to change once it's installed.
whitetiger5 (11-01-2019)
Old 11-01-2019 | 03:39 PM
  #702
GRWeldon's Avatar
Too late...Already took the cover off. The fluid looked so black after I drained it that I decided to pull off the front cover to look for built-up crud. I put a couple of drops of the fluid from the drain pan on the white paper towel to show the true color. You can't even see the fluid in the black plastic pan because its so dark! Surprisingly, the interior (at least under the cover) looked fairly clean. Burnt black fluid pooling in the corners but no piles of black, cruddy friction material. The external filter didn't look horrible, but was doing it's job. I would guess by the condition of the car that this tranny was removed from that it had closer to 200K miles on it rather than 100K.
Oh well, it's easy enough to put the cover back on and button it up again. Certainly going to put in a new or remanufactured TC. Going to change the TC seal as well as the rear crank seal. Anything else I should look for before installation? I just pressure washed it today and removed most of the grime. It had a leaky axle seal and I also think the rear crank seal was leaking.
Old 11-01-2019 | 04:05 PM
  #703
Iggy's Avatar
As these things age I would recommend one other seal in addition to the rear main crank seal. Check out my post here: https://acurazine.com/forums/second-...6-swap-983133/
Old 11-01-2019 | 04:35 PM
  #704
GRWeldon's Avatar
Thanks Iggy...I probably would have pulled the place to replace the crank seal and would have noticed the O-ring, but now I know it's there and know it needs to be done. I'm also replacing the oil pan due to stripped out and ill-repaired drain plug threads. Anything else that I need to be aware of while I have the pan off?
Old 11-13-2019 | 10:30 PM
  #705
19Ralph93's Avatar
Will the av6 work for my 05 TL
Old 11-14-2019 | 07:46 AM
  #706
horseshoez's Avatar
Latent car nut
Yes, lots or threads here on the subject; "Search" is your friend.
whitetiger5 (11-14-2019)
Old 11-14-2019 | 12:19 PM
  #707
GRWeldon's Avatar
I'm not an expert, just been reading a bunch here about it, but you will have to use a torque converter from an 06-07 Accord. Apparently the 05 TC will not bolt up.
Old 12-11-2019 | 06:52 PM
  #708
Cali962's Avatar
6th Gear
I have no idea where I'm supposed to ask this but I have a 02 acura tl type s with a blown tranny I just need to know what I can put in it or of there is another permanent fix besides the 06-07 accord because I've that 3rd gen tl can work but I was also told that an 08 tl wont work, but isnt that a 3rd gen trans ? Just so very confused again sorry if this isnt the right place for this I just joined today
Old 12-11-2019 | 07:00 PM
  #709
no, it's your best option.
Old 12-12-2019 | 09:34 AM
  #710
horseshoez's Avatar
Latent car nut
As already mentioned, the 2006-2007 Accord V6 transmission is your best option. Regarding the 3G TL transmissions, the 2004-2006 transmissions will fit, but they aren't considered any better than your transmissions, the 2007-2008 transmissions have a different mounting pattern between the engine and transmission, so they will definitely not fit.
whitetiger5 (12-12-2019)
Old 12-12-2019 | 09:53 AM
  #711
Cali962's Avatar
6th Gear
gracias for the explanation
Old 12-18-2019 | 02:08 PM
  #712
SuperGreg's Avatar
FWIW I put an AV6 in at 206K miles, just hit 245K and still running like a champ. My son is driving the car now.
Old 12-20-2019 | 09:26 AM
  #713
Cali962's Avatar
6th Gear
So I bought a 07 trans but just to be sure I just need to switch the cooler the range selector and every bracket from my 02 type s and use the accord torque convertor
Old 12-21-2019 | 05:31 PM
  #714
GRWeldon's Avatar
The Accord Converter did not fit my Acura flexplate. I re-machined it to work. I couldn't get a straight answer as to why. Mine donor came from an 06 Accord.
Old 12-21-2019 | 07:52 PM
  #715
horseshoez's Avatar
Latent car nut
I have anecdotally heard early 2006 model year BAYA torque converters were slightly different than the rest of the BAYA torque converters.
Old 12-21-2019 | 09:00 PM
  #716
Cali962's Avatar
6th Gear
mine is from 07 so I'm hoping I dont have that problem I just wanted to make I got right the other things I was switching
Old 12-21-2019 | 10:49 PM
  #717
Most replace their rear main seal while replacing the transmission; this requires taking the flexplate off: while it’s out is a good time to line it up with the AV6 torque converter and make sure the two match.
Old 12-22-2019 | 08:03 AM
  #718
horseshoez's Avatar
Latent car nut
Some of the best advice possible!
Old 12-22-2019 | 09:40 AM
  #719
Cali962's Avatar
6th Gear
Rear main seal was part of the plan, but lol still trying to make sure the other things are correct which is switching over the range selector the and brackets from the tl type s and the cooler
horseshoez (12-22-2019)
Old 12-30-2019 | 04:03 PM
  #720
Taahaa's Avatar
6th Gear
03 TL to AV6 Swap Help Required
Hello everyone-
Been a lurker of this forum since two years ago when I first bought my TL.
While I understand that a lot of people have successfully completed this swap however unfortunately I went to three mechanics in my area who downright laughed at my suggestion of doing this swap. They stated that all transmissions are different and 06/07 transmissions would have more solenoids, therefore this swap is not possible...any idea why they would say something like this when it has been done before?
Lastly, since so many people have done this, please tell me if anyone got it done from the DMV area? (I don't have the tools or know how to do it, I could learn but it would take a longer time)
Thank you,
-T
Quick Reply: FAQ: 06-07 AV6 Transmission 'Swap'
