factory audio
Old Jan 25, 2012 | 04:47 PM
FrankWhizzite's Avatar
factory audio
where is the factory amp located in this car? also, can the sub be replaced by a larger one? trying to figure out the best way to upgrade. thanks
Old Jan 25, 2012 | 05:49 PM
NJoba147's Avatar
under the back seat. and your best bet is buying an aftermarket sup and amp
Old Jan 25, 2012 | 09:26 PM
gold2003tl (90)'s Avatar
2003 TL-p
take the back seat out, the amp is a small box on the passenger's side part way up the back side. its like a 100 watts so your not going to be able to run a larger sub off of it, let alone its not even enough for the cruddy stock sub. Id recommend removing the stock sub woofer and amp, and replacing it with a better after market system. check out the audio section, there is more info over there.
Old Jan 26, 2012 | 10:08 AM
fsttyms1's Avatar
Factory amp for the door speakers is built into the headunit. Factory amp for the sub is located passenger side behind he rear seat.
You cant really add a larger sub to the rear deck. 1 the torsion bars are in the way, 2 its a goofy size, 3, its a shallow mount free air sub, 4 the rear deck really wasnt designed to hold something bigger. If bass is what you are after,Your best bet is to do a custom enclosure and aftermarket amp.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
navtool.com
Sep 25, 2015 05:15 PM
