Exhaust systems
Exhaust systems
I have a 2002 Acura TL base and I was wondering what would be a good catback or axle back exhaust? I don't want anything to loud and flashy. Something deep sounding. I've been looking at the takeda exhaust but I'm not sure if I want to spend the 800 dollars for it. Thanks
Former Sponsor
The Tanabe is the way to go. It's made from higher quality materials and will fit better/last longer. Plus it's a full catback system which frees up more air flow.
Tanabe Medalian Exhaust - Medalion Touring - Excelerate Performance - Japanese and European Performance Specialists!!
Former Sponsor
Catback usually tune their systems to the magical limit of 89db by DOT standards
TL Straight Pipes usually don't come out any louder while at Idle and almost the same loudness at WOT than an Aftermarket Catback.
I reckon my TL sound almost exactly like an APEX´i catback for the TL.
So if SOUND LEVEL is an issue to the OP I don't know why he would want a Catback on the first place! Any system will be louder than stock if not what its the point? Performance? Catbacks have the worst "HP per dollar" ratio for the mod.
.. That is way LOUDER than stock lvl of 60-65db.
If sound level isn't an issue then try Straight Pipes first! The J32 has a natural deep growl to it and straight pipes accentuate it perfectly.. At idle you wont find it bothersome like some "fartcannons" and at WOT it will actually muffle the intake sound sounds wayyyy badass.
Heres is my Thread about it: https://acurazine.com/forums/second-...-sound-919409/
HairyMonkey also chimed in with his video on the lower comments.
Only reason to use a Catback over Straight Pipes is if your State is very hard on Sound Level limits or your inspection actually has a muffler db test.. So when you do Straight Pipes do so AFTER the Y-Pipe on the Axle-Back.. Don't WELD anything!!!! Make your muffle shop install new flanges for the straight pipes so its totally reversible! That's how I did mine.. I can re-install the OEM mufflers just in case in less than 5 minutes.
joflewbyu2
10-08-2015 11:16 AM
johnpancakes014
09-27-2015 12:58 PM
