exhaust resonator removal
ive been searching for a DIY on the removal of the exhaust resonator. i want my car to sound alittle bit louder, deeper than it already is. but i dont really want to keep spending so much on my car. i have to pay for college and everything else. does anyone know how to remove it. i know i have to get it on a lift, and i know where i can do that. but where exactly is the resonator and what's the easiest, best way to get it out?
oyeah and what are the benefits and how loud is the sound going to be? like.. the nissan VQ engine/exhaust loud or civic fart cannon loud? truck? obnoxious? deep nice grunting loud? just want to know ahead of time for what to expect.
well.. our cars already have pretty nice freely flowing exhausts so it doesnt really do much for better flow.. although it should, but its not really for performancewise i guess.. more for just the sound.
i
woooo!!
Originally Posted by moahdriven
exhaust resonator is the muffler looking thing before the Y-pipe. I guess best way to get it out would be to saw it off and then jus take a straight pipe and weld it in its place. A muffler shop should charge no more than 45 bux to do it.
i
Originally Posted by subtledreamer
i dont see how you can saw off the resonator yourself and wield a straight-pipe back on... take it to a muffler shop and see how much it is, shouldnt be too much like moah said.
woooo!!
well, if uve got any kind of power tool that can cut well, jus cut it out. U can buy pipes at any hardware store, and if uve got welding tools and experience then u can weld em on. But yea, I'd trust a pro with that kinda work.
huh.. the thing is, i have proper cutting tools and i have a friend that has experience in welding.. but if it doesnt sound that great than there's no point of doing it.. but isnt a CL different from the TL? like the width of the Y-Pipe, downpipe and everything else? wouldnt they have a different sound since they got wider pipes causing it to get louder noise..
Originally Posted by mclarenf3387
Don't do it. Your car will sound like crap. CL guys have done it before and they all wind up putting it back.
as for doing it your self it would be best to let a muffler shop cut it off and weld in a new piece but you could always cut it out your self, have a muffler shop cut you a piece of pipe and flare both ends and clamp it on too.
now if you have a aftermarket exhaust i would do this mod with caution, because it will make the exhaust alot louder. the TL with comptech exhaust and this mod sounds nice (not like a civic with a fart can) but the resonance inside the car can get over welming at times, unless you have the quiet tip inserts
Comptech Freak
aaron
you can swapped all the pipes with a wider pipes, more flow and more hp and more sound
but that is not cheap thou, like 200-300 dollars including labour
One on the right for me
Several ways to go about doing this. Easiest, of course, is to get an exhaust shop to do it (my shop charges 35 for removal of a resonator). Second, you can cut out the resonator yourself and then get some straight pipe with an inside diameter slightly larger than the outside diameter of the exhaust and slip it over, then use clamps (make sure to get them tight). You can also attempt to do it yourself if you have a welder, although its a pain in the ass to weld if you are not standing under the car and your welds will probably look like shit. Be careful when removing the resonator because that will give the car a weird tone...maybe louder but not necessarily deeper (and if it does turn out to be deeper, it will be raspy). In the roughly 300 cars I have removed resonators on, the only consistant thing was the tone was not as smooth or mellow...some people like that, personally i dont.
Originally Posted by 55M2G7L
so basically with headers and a apex'i ws catback if i remove the resonators the car will probably sound like garbage?
i llike the way the comptech sounds with out them, but i do use teh quiet tip inserts alot too.
see how you like the sound with teh headers and apexi cat back before you change any thing
wow.. alot of comments. thanks for your inputs. the thing is i really dont want to get an aftermarket exhaust. i just want it to sound alittle bit louder. ive heard cars with just exhausts on and it just sounds too beastly for an acuraTL. just want alittle bit of that sports feel when listening to my car accelerate. well, i guess we'll just have to see what happens when i take it off. probably this saturday. and i'll tell you how it goes. since most of you guys said it wont make much of a difference with jsut the OEM mufflers i guess there's nothing to lose, right? thanks again
Boomer SOONER
you can play with the resonators...I mean there are 2 of them, try different combos. or get a Magnaflow resonator and try that, there are all sorts of different lengths you could try also.
woooo!!
of course i'll have video clips. i always take pictures and keep a record in everything i do with my car. all the projects ive done i always kept it updated with pictures.
damn, im still debating on doing it or not.. most likely i will, just scared if it'll sound really obnoxious
Originally Posted by 1nePhatTL
do it, i have the same thing, youll love it. kinda sounds like the G35. I have both of them off.
i
now im DEFINITLY doing it!!
Originally Posted by ou sig
YYYYEEEEEEESSSSSS!!!!
johnpancakes014
04-08-2016 06:47 AM
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
IIDXholic
10-08-2015 07:53 AM
