Engine Shakes While Idling
Old Feb 15, 2013 | 03:19 PM
Nicks2001tl's Avatar
Changed the spark plugs and coils and the front mount and the side mount.
The rear mount after removing it looked to still be in good shape so I reinstalled it.
Just did an oil change and tranny fluid and filter change.
With all this it starts fine but engine still shakes at idle and needs to warm up quite a bit until goes away.
Old Feb 15, 2013 | 03:40 PM
MilwaukeeDave's Avatar
Which plugs did you install??
Old Feb 15, 2013 | 04:07 PM
Ngk Iridiums
Old Feb 15, 2013 | 04:31 PM
gold2003tl (90)'s Avatar
2003 TL-p
its either the wrong plugs or the rear motor mount. If the shaking is coming through the steering wheel then its the rear motor mount.
Old Feb 15, 2013 | 04:42 PM
Steering wheel doesn`t shake. Spark plugs makes sense.
NGK Iridiums or Oem?
Old Feb 15, 2013 | 04:57 PM
NGK iridium are correct. You can't visually say the mount is good, you have to load test it in the car. Test it under a load by standing on the brake and put car in D and rev it a little. Look for excessive engine movement. 2 person job. Pick a friend you trust so you don't get ran over.
Old Feb 15, 2013 | 07:27 PM
I put ngk`s in on sept 2012 and since then seafoamed the gas tank a few times and the vac line 2x.
Is it possible that the spark plugs could of failed after doing some deep cleaning.
Reason being I read somewhere on here that spark plug change should be done after you deep clean the vac line and fuel lines...
Old Feb 15, 2013 | 09:01 PM
Pull em out and check them. It shouldn't take longer than 20-30 min.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
vpasla1
Sep 17, 2016 07:24 PM
IlliniAcura
Sep 19, 2015 09:31 PM
redsox68
Sep 16, 2015 06:18 PM
Mike Bertram
Sep 10, 2015 09:27 AM
