Engine running a bit rough
I have a 03 tls with 45,000 miles on it
I noticed that when I was at a stop, the tach would slow a bit and the engine would be running a bit rough. It sounded like the engine wanted to stop but it didn't It would then rise a bit to normal. It would then continue this cycle.
It was doing this for two weeks. The battery then died. I replaced the battery yesterday and the behavior continued for that day and then disappeared. It's been fine today. It noting to do with the ac
I called the dealer and asked if a weak battery would cause the problem. She wasn't sure and though the fuel injectors needed to be cleaned and to bring the car in.
What do you guy think?
A weak battery definitely will cause rough idle. but, like ftty1 said it could be many things that you will need to narrow down slowly until the problem can be pinpointed. Your car has low mileage so it is hard to guess anything is wrong.
Originally Posted by phipark
Possible IACV?
Engine Idle Quality
Idle and IAC Valve
There has been some confusion over the exact function of the IACV (Idle Air Control Valve) and it's role in maintaining a smooth idle speed. In fact it is the EEC-V PCM which controls engine idle, not the IACV. The IACV should really be called a 'Throttle Air Bypass Valve' because this is all it does.
The EEC-V receives signals from the IAT and the ECT for the temperatures of the inlet air and the engine, from the TPS for the command position of the throttle, from the MAF for the actual amount of air drawn in through the inlet manifold and the Engine RPM is calculated from the CKP input. It also receives an input from the Air Conditioning clutch cycle and the Power Steering Pressure (PSP) switch (to compensate for the drag of the compressors) and the Park Neutral switch to show the command state of the automatic gearbox when fitted.
From all these the EECV computes the LOAD on the engine and before each cylinder fires it computes:
bullet The correct spark advance in degrees BTDC - (PID #111b SPARKADV)
bullet The pulse width of (each) bank in m/s - (PID #1141 and #1142 FUELPW1 and FUELPW2 in Enhanced) when hot using both LT and ST fuel trims - CLOSED LOOP. When cold without emission control the fuelling is inOPEN LOOP.
bullet The correct position of the IACV duty cycle 0-200% (PID #1153 in enhanced).
These are 24V PID addresses for use with the OBD2 software and reader - other engines may differ.
The nearest approximation of the conventional 'Choke' is OPEN LOOP when the HO2S sensors are cold, but they have heaters in them to bring them up to temp very quickly - when the PCM switches to CLOSED LOOP the engine itself is still quite cold. If you block off the Idle Air Bypass Pipe at this point the EECV cannot maintain the engine idle - combustion is too fragile. However, once the engine is at full operating temperature the programming can maintain idle by varying the spark advance and the pulse width - the heated cylinders are much more amenable to these adjustments. Blocking the bypass pipe like this is just one demonstration of how powerful the EECV is and how it can maintain engine function under quite extreme conditions.
Because engine control is holistic, the chances of an EEC-V controlled idle being effected by a dirty IACV is probably 10 or 15 to 1. It is always worthwhile cleaning it on the EEC-IV 12v engine variant where this was quite common, but much less so on the newer engines. Experience shows that a failed IACV normally causes stalling rather than a poor idle.
Diagnostics
So, if you are experiencing a poor quality idle on your 16V or 24V engine then the following order of diagnostic work should be undertaken :-
1. An air inlet leak causing unmetered air to enter the inlet manifolds. These can be split or disconnected vacuum pipes, a loose EGR pipe, faulty EVR, split/loose air bypass pipe, split inlet O rings especially after disturbing the inlet system. In particular there is a plastic vacuum T piece located underneath the central throttle body of the inlet manifold which is very prone to failure (Two of the Ts are 4mm and the other is 6mm) and is no longer available so you may have to make your own replacement if this has fractured.
2. Faulty EVAP system, loose or faulty petrol filler cap. Make sure the filler cap is ratcheted tight.
3. Lost TPS position. Check for P0122 TPS Sensor Circuit Low, and on the DATA page check the % figure for the TPS. Static the TPS should show 16% approx. If the reading is lower, then the EECV has lost synch with the TPS. Fuelling will be poor, idle effected by lurching or surging. On autos, you may also notice that the gears are being selected with a thump, both when stationary and on the road. If the DTC and the percentage reading is seen then force a resynch by disconnecting the battery for half a minute. Don't forget the radio codes before you do this, however. After the initial poor running while the running parameters are relearned, the engine idle and autobox changes will be greatly improved.
4. A 'Hanging throttle' - engine delays at higher revs when accelerator is released, then revs die suddenly, revs stick high and engine races irregularly without touching the accelerator - is probably caused by a sticky throttle butterfly valve, particularly on the DOHC models. Grime and burnt oil (from the PCV system) can gather round the throttle plate and cause it to stick slightly open. Clean the inside of the throttle body with good quality carb cleaner and an old toothbrush.
5 . Faulty connections on or flatlining upstream HO2S (Lambda) Sensor. These are the ones located on the engine side of the Catalytic Converter - those after the Cats do not affect engine performance.
6. Faulty MAF. Where the element or conditioning electronics has failed a MAF will not produce a meaningful reading to the PCM. This will result in a surging idle, and probably also jerky, thumping autobox gear changes and a P0102 Diagnostic Trouble Code. The MAF will show typically 0.000 to 0.005 lbs.p.m. at idle or KOEO
Where the element is failing or corroded the MAF may show too high a reading. This drives the Long Term Fuel Trims too lean. This is detailed on Faulty Maf
7 . Faults with the Ignition modules or wiring (on 16V engines in particular), but the EI module on the 24V has been known to split at the rear.
8. A slightly racing idle may be noticed on occasions when the petrol tank is nearly empty. Idle is corrected when the vehicle is next filled up and this is not a concern. However, a persistently high idle, surging or racing, allied with thumping into gear [autos] or dragging on the clutch, bulking in reverse [manuals] then see (3) above.
9 . Quite Rare - incorrect installation of the 24V camshafts during an engine rebuild. It has also been known with the 24V for the cam chains to jump sprocket teeth when the timing chain has become very badly worn.
I apologize for hijacking your thread. But it seems that i have rough start ups. I mean..it only happens when I turn the car on and off alot in short intervals. Lets say I turn the car off and go to a supermarket..I then start the car back up and the engine would run a bit rough and the TCS light will come on. It eventually goes away (in about 30 seconds)..but i'm wondering if this is a result of a weak battery.
Originally Posted by 2000tl32
Not accord this website which says:
Engine Idle Quality
Idle and IAC Valve
Engine Idle Quality
Idle and IAC Valve
I had the exact symptoms as you discribed.
It was due to almost-dead battery for me as well.
I left my car in the garage for the entire school term.
And during the school term, I had to boost start the car every time I want to drive the car because I left it too long in the garage.
The car shows the exaxtly same symptoms(where at idle the rpm drops down as low as 500 rpm or lower and up, then down again, then up, so on and so forth) that you wrote above until it was charged enough after driving around 20~ minutes.
If that happens again(not likely with new battery), I suggest you to shut off your head lights, audio and others that might be sucking on your battery and drive for a while to recharge your battery.
mada51589
05-03-2022 08:54 PM
TLDude876
12-28-2016 03:18 PM
