Engine mounts?
Engine mounts?
I was looking under the hood and was curious where all the engine mounts were, i only found 3 so far and here they are:
side engine mount near the power steering pump
![](http://i586.photobucket.com/albums/ss305/xlost8/IMG00145-20100118-1242_opt.jpg)
front engine mount (front of the car near radiator)
![](http://i586.photobucket.com/albums/ss305/xlost8/IMG00146-20100118-1242_opt.jpg)
rear engine mount (near the firewall at the rear of the engine)
![](http://i586.photobucket.com/albums/ss305/xlost8/IMG00147-20100118-1242_opt.jpg)
i can see that my front and rear are vacuum controlled because i see little lines going to them.
i see 3 mounts but where is the transmission mount and the other mount. i was told there were 5 mounts total, so where are the other 2?
i know i need to change my mounts out because i feel a lot of activity in the cabin which i shouldn't be feeling. so i am going to replace them but i need to know where the other two are.
And are they easy to replace yourself at home? or do i need a shop to do them at?
also while i was looking under the hood i saw two solenoids near the transmission fluid dipstick:
![](http://i586.photobucket.com/albums/ss305/xlost8/IMG00148-20100118-1244_opt.jpg)
(i circled them in red. so i suppose those are the shift solenoids and it has a screen which you can clean optional, right?)
Thanks in advance for the help
well that basically answers my question then. the last two mounts were 2 transmission mounts. 1 for the front and 1 for the rear of the tranny.
so there are:
1 side engine mount
1 front engine mount (vacuum controlled)
1 rear engine mount (vacuum controlled)
1 front tranny mount
1 rear tranny mount
now all it takes is for me to visually see them and i believe the only way to see the 2 tranny mounts is to use a auto shop lift and i have those at my college auto shop so that works perfectly!
thanks dude![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
so i assume those mounts are on http://www.acuraoemparts.com/delray/jsp/home.jsp
i will check them out. i got my 105k service coming up and prepared for it. i'm not sure whether i should go to honda or acura.
all i know i need to get changed on the 105k service is:
timing belt
water pump
tensioner
idler pully
seals
valve adjustment
coolant flush
power steering fluid flush
and i think that's it because i can do the oil, tranny fluid changes myself.
so there are:
1 side engine mount
1 rear tranny mount
thanks dude
timing belt
water pump
tensioner
idler pully
seals
valve adjustment
coolant flush
i just checked acuraoemparts.com
![](http://www.acuraoemparts.com/delray/jsp/catimgs/13s0k0_b47.gif)
#2- front tranny mount ($30)
#3- rear tranny mount ($15)
#7- side engine mount ($66)
and i got a question regarding the front and rear engine mounts.
i believe the front is #5 so whats the rear number?
Always Working In
#5 for the front and #6 for the rear. Tranny mounts can be seen in the driver side wheel well. The front one near the sheild underneath. Follow the diy for mounts in the diy section. They're all pretty easy except the rear is a little cramped but I found a good "z" pattern exit once you get it loose helped out.
2003 TL-p
i had my side and front motor mounts replaced along with my tranny. too bad no one makes an engine damper for our car, it would most likely extend the life of the mounts.
okay so i got the prices all together for all the mounts. it's clear to me now.
#5- front engine mount ($76)
#6- rear engine mount ($119)
trust trying to figure out why the rear engine mount is so expensive!?! i mean wow the tranny mounts are the cheapest and easy to replace and those are probably the ones that are shot on my part because i can feel the tranny when i put the car in reverse.
i will start with the tranny mounts and work my way to the side mount and the front and rear.
i'm still awaiting my 02-03 wheels. can't wait to put those on
i'm still awaiting my 02-03 wheels. can't wait to put those on![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
B A N N E D
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
also to xlost, found out why i felt vibrations on my car, side mount had gone bad
WNC Real Estate Sales99TL
I replaced the front and Pass. side mount. Very easy to do. The don't think the front mount is $30. It's more like $70-90. What a difference! after changing them. The rear and Tranny mounts were ok. If I remember right it was about $140.00 for both front and side mounts.
if your front mount is vac boosted its NOT 30 bucks- its closer to 100 same as the rear.
ON gen2 it boost mount stiffness/strength with vac pressure change on full throttle-
gen3 went oppposite and it smooths at idle on vac boost mounts
In MOST cases the front mount breaks somewhere around 50kmiles and goes unnoticed- then the pass side takes more load and it breaks, finally the trans fails about that time -- tech notices oil from front mount and advises replacement
rare is the car that needs all 5,, and not starting with trans- start with the KNOWN failure points
xlost- make sure to get the idler/roller pullies for timing belt- anything that moves and you expect to last another 100kmiles do now
the coolant flush is part of the 105 as they remove coolant to get pump off
Often wise to replace radiator hoses now and thermostat for good measure- DIY projects
may as well do ac pulley while in there and its belt
cam seals are usually ok
valve adjust is a very good idea.. always a few are off spec
adjustment can be even better if you seafoam the oil- drive- then change, before the service
That will leave the surfaces clean and ready for precise adjustment
ps flush is DIY- very easy, do it twice to rid system of crud- starting fresh for the next 100
so with you saying that if any mounts fail its more than likely the front and the side which will need replacement.
so i will do those sometime when the weather breaks and it warms up.
valve adjustment is something i want to try on my own. but i might have acura or honda do it. i don't know yet.
but i have been using seafoam a lot lately. i put 1 can in the gas tank on a full tank once and noticed improvement. i just hope it doesn't contaminate the new spark plugs i installed a week ago.
the oil, tranny, coolant, power steering fluid was all going to get changed regardless.
the tranny fluid is what i will do anyway because i think its due and i don't want my clutch packs getting burned or heated up.
dont overdo seafoam!!
repeat manifold and gas methods after a month then good for a year
Start with a cleaning dose in gas tank- 2 oz per gal of gas - thats 1 16oz can to just under a HALF tank ~8 gallons
`maitenance dose` is 1 oz to 1 gal= 1 can to just under full tank- ok to do every 5000 miles if you want to really stay on top of the always clean program
the gas tank method will NOT foul your new spark plugs or cause any issues!
spark plug probs after manifold vac port use only happens with very very old plugs.. like 100kmiles and no or little afterdrive done..of course stuff gets stuck to them
Do a visual check from under car at front and rear motor mounts- look for oil or dirt trail attached to the oil that leaked out
or a few drops of strange oil on driveway,,unlike any oil I had ever seen used in the operating of the car! knew something was wrong
Do the manual test of standing next to the car and watching for engine movement when revved in drive- with blocks in front/rear of wheels and trusted friend behind the wheel and controls holding brakes tight
vac boosted mounts that are broken also cause a mystery vac leak and slight engine miss, If its bad replace ASAP, the DIY section has instructions
When we say `front motor mount` we mean front of car, not front of engine,
where we call the mount at that end (which is the real `front` of the engine)
the `passenger side mount`
rear mount is the one at firewall end of the system and matches front mount
ie: the 2 big ones do the most work-front/back motion
Hint: Everything is from the seated drivers perspective when ordering parts
front and rear mounts are expensive- retail $100-130, passenger side is the 30-50$ mount
yeah, just found out that my mounts went, there car is going notice, i feel it in the driver side wheel well, since the engine is moving so much. i feel like a clunk when i let off the accelerator.
How do i check which mounts are the bad ones??? where would i notice leaking. i was thinking of replacing my front and side and tranny ones.
how do people feel about these mounts??? i know some people are against buying from no name companies or ebay or anything like that.
http://www.amazon.com/Honda-Accord-A.../dp/B000PZ8A1Q
I just replaced these mounts today actually and they were super easy.My buddy and I got the job done in a hour. i replaced the pass. side mount and the front egine mount and the "clunking" noise is no more!!!!
the pass side mount was $52 and
the front mount was $120 @ autozone
so are all 99-02 mounts hydraulic, well the front and rear??? or are they different by years, i drive an 01, and it has 2 feet of snow on it right now, so im not quite sure which ones i need, maybe someone can tell me by year?? or is that not possible.
Yes, they are all hydraulicl. Only the 99 has a different mount. The 00-03 are the same (# 50800-S0K-A82) mounts
sockr1
10-01-2015 01:31 AM
