Engine Mounts
Old Jun 28, 2009 | 03:47 AM
III.II's Avatar
Question Engine Mounts
Which engine mounts are the best?
I've read about the Innovative Mounts but there seems to be a lot of problems with them.
Other than that is there any other brands that are good?
Or
Should i just get OEM ones?
Old Jun 28, 2009 | 03:50 AM
01tl4tl's Avatar
OEM from a dealer on here for stock smooth ride and vibration free
the solid polymounts give a lot of feedback~
wholesaleacuraparts was mentioned for timing belt deal- maybe for this too
or Tim at hondaacuraworld is known to have a good price for ziners
usually its the front and passenger side that break
Old Jun 28, 2009 | 03:14 PM
spoka's Avatar
OEM unless you own a race car
Old Jun 28, 2009 | 03:59 PM
DC3328's Avatar
Your Garage
poly filled oem mounts, it reduces wheel hop
https://acurazine.com/forums/2g-cl-2001-2003-50/custom-poly-engine-mounts-699597/
Old Jun 28, 2009 | 04:32 PM
TheSentinel's Avatar
https://acurazine.com/forums/showthread.php?t=699597
I concur I'm prolly gonna do a write up for the TL version because it is slightly different in that the mount configuration is different and if you do First tip, USE gloves. I'll be putting some un-mixed poly in the black market that is recommended.
Got my mounts from WholeSaleParts guy, really helpful.
Old Jun 29, 2009 | 11:18 AM
rob-2's Avatar
Just replaced a mount a month back with an OEM unit. THey seem to last a while for me.
Old Jun 29, 2009 | 03:07 PM
fsttyms1's Avatar
The ONLY difference is between the 6 speed vs auto, other than that the TL and CL use the SAME mounts and configuration.
Old Jun 29, 2009 | 10:33 PM
adamlee05's Avatar
Thread Police Chief
^-- and even then you just deal with 2 new brackets basically. EXACT same process regardless.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
