Engine Mount control system?
I have looked everywhere for detailed info on how the system works and what it does. I replaced the front mount with a mount that does not include the vacuum connection and am wondering if I should just plug or disable the entire system or if this engine mount system actually does anything substantial. Anyone know?
I have the service manual but just tells how to test it not much more. If I have to I will buy an Acura mount and replace it but just don't really know how necessary it is.
If you replaced both mounts then unplug the solenoid and plug the vac lines. If you only replaced the front then just plug the front vac line
phee.. engine movement was my clue. It should be tight. When I took out the side mount it was deteriorating badly (inch or so of play). The front was oozing oil. I think if you have as many miles as mine (120k) and never replaced the mounts just do it. They are probably shot. Just my opinion.
Originally Posted by phee
thanks for the info man. ill look into it, i dont know how much movement is too much movement :/
Sorry I guess I forgot to say thanks for the help.
I have completed my Timing Belt, water pump, motor mount, drive axle, rotors & pads, new belts adventure.
Feels a bit rougher with the non hydrolic mounts but not a big diff. Getting the infamous PS noise as well. Oh well. Only tightend from squeel to no squeel for the belt but who knows. All else seems fine
Thanks again for the help
WNC Real Estate Sales99TL
My front and side (Passenger side top mount) are shot. (99 TLP with 89,000 miles) How I found out what it was=I raised the hood put my car in drive, applied the emergency brake and blocked up the front wheels. Gave it a little throttle while under the hood while the car was in DRIVE and could see the side engine mounts move and noticed that the rubber was split on the upper passengers side mount and it was moving quite a bit. The front motor mount would raise up at least 1/2 inch or more when I applied a little throttle. Also noticed that when I would start out in the car with a little extra throttle that there was apparant engine / tranny movement. I don't drive hard= no jack rabbit starts etc. They just fail! Ordering new ones today.
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
