Engine Jerking From 4th To 5th Gear
Old 01-26-2007, 12:55 PM
myTaLizaS3.2's Avatar
In the begining, i thought it was "slipping," but someone straightened that up with me. But now i notice that the engine jerks more than it used to from 4th to 5th. Engine mount problem? How much to replace if it is?
Old 01-26-2007, 02:15 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
doubtfull that its a mount. It would do it in all the gears
Old 01-26-2007, 02:56 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Arent you driving a 02 still under the factory warranty on the transmssion?
If not sure call acura care at 1 800 382 2238 x 5 and ask- have your vin number in hand
On the acura.com website there is a list of what are syptoms and what are normal.
For instance, slightly harder shifting for a few minutes when cold is actually a design feature! Go Figure
My TL started having slight sypmtoms of slipping under extreme test conditions, then 2nd wasnt great, then the D5 light flashed getting on the freeway and ptttt new transmission
IF IF IF your car needs a motor mount- not uncommon on these cars, the front should be about 120$ part and 30$ labor the side mount is about 30 and 30 I think, mine only needed the front====I am talking about price on labor --ONLY if done WITH transmission --swap- otherwise its much more
Old 01-26-2007, 03:10 PM
supposedly, the tranny was fixed for watever already before i bought the car. i drive like a maniac so i tend to jerk the car a lot. maybe it messed up a mount. do they make bushing inserts for our mounts?
Old 01-26-2007, 03:31 PM
fsttyms1's Avatar
Well just because it was supposedly fixed doesnt mean it is in normal operation.
And
No, they done make bushing inserts for the mounts
Old 01-26-2007, 05:26 PM
On the way!
fla-tls's Avatar
Very doubtful it's a mount. You feel mounts more when intially shifting the car, and in the lower gears (because the torque on the engine/transmission is greater). If the 4-5 shift is the only hard one, you probably have transmission problems.
Sorry it's not better news.
Old 01-26-2007, 06:24 PM
I Only Notice The Hard Shifting When I'm At A Low Rpm Though. I Have 200 Miles Left Until My 50,000 Warrenty Ends. Hehe. Gotta Squezze It In Then
Old 01-26-2007, 09:10 PM
01tl4tl's Avatar
Call the dealer saturday- maybe service is open and you can get an appointment for Monday
Otherwise just show up on their door Monday, ask for a loaner car and be done with it
Get it in Monday for the seat heaters to get fixed under the 4/50 warranty that covers all
IF IF IF a motor mount is bad- the 4/50 should cover that too
Transmission is a special warranty that goes to 7 years 100 thousand or 109 depending about the court decision
Most likely, and you can find this out on by registering your car on acura.com ownership experience, the oil jet spray bar recall was done on your car.
Not same as transmission failure at the clutch packs!!!!!!!!!!!! Which is a warranty not recall
Online it will say if new trans installed or it will say oil spray bar- completed
Your car has issues - get it in before they become your problems too!
Old 01-26-2007, 11:39 PM
well seat heaters are fixed. My car isn't covered under the 100,000 warrenty. Already checked. I am registered at acura.com. This is what it says on the site...
Description 00-04 CL & TL A/T RECALL
Date 6/29/2004
Type Safety Recall Campaign
Status Fixed
Old 01-27-2007, 12:22 AM
01tl4tl's Avatar
the 6/04 were for the oil jet- it was a RECALL
The trans is an extended factory warranty - CALL Acura Customer Service at
1-800-382-2238 x 5 and ask
Who exactly told you that you are not part of the vin's covered by the 100K trans warranty?
I dont know the cutoff vin number- but with the ongoing probs I would always ask
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
NitroViper
03-20-2017 09:50 PM
George Knighton
3G RLX (2013+)
176
09-16-2016 08:26 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
Skirmich
09-15-2015 06:41 PM
Quick Reply: Engine Jerking From 4th To 5th Gear
