Engine ideling up and down of my Type S can anyone help
Check your coolant level. Also make sure that it doesn't have air trapped in the system. If that all checks out, then try cleaning your EGR or ISC. But, usually they will throw a code. Another thing to look for would be a possible vacuum leak.
Most likely its the Idle Air Control Valve (IAC) you can take it off (its on the bottom of your Throttle Body) and clean it. If it continues you may need a new one.
sockr1
10-01-2015 01:31 AM
Billu99tl
09-13-2015 11:30 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
