Engine FAN!
Old Mar 16, 2004 | 11:27 AM
dtpjigzer's Avatar
Yeah, its STOCK!!!
Engine FAN!
alright... Before my car went into service for the 2nd dead tranny replacement.... my fan never stayed on after turning the engine off. But now... it stays on everytime after driving for like 10 minutes. is this normal??? im afraid the dealer fvcked up my car.
Old Mar 16, 2004 | 11:29 AM
Severin's Avatar
I always thought the fan was thermostatically controlled and will remain on as long as the coolant is above a certain temp, whether the car is on or off.
Old Mar 16, 2004 | 11:33 AM
`ill*tl's Avatar
It's normal. Reason is when you shut off your car, your engine is still hot and since it's not getting cool air circulated into the engine, your fan should turn on for a bit..and should turn off when your engine gets cooler.
Old Mar 16, 2004 | 01:44 PM
`ill*tl's Avatar
Old Mar 16, 2004 | 01:58 PM
dtpjigzer's Avatar
Yeah, its STOCK!!!
my car has 18000 miles now, the fan never turned on until AFTER the 2nd tranny replacement!!! WEIRD!!! I guess the car is finally working NORMAL! lolz!
Old Mar 18, 2004 | 10:10 PM
RACINGHART03's Avatar
Check your coolant. Antifreeze lines are taken off when a trans is removed...if the tech didnt top it back off...your car may be running a lil warmer thus causing your fans to run afteryou shut it off.
Old Mar 18, 2004 | 10:15 PM
Ken1997TL's Avatar
Its normal. The fan NEVER ever stayed on though for my '88 Accord and Civic, maybe they never got hot enough.
Old Mar 18, 2004 | 10:20 PM
Older honda and acuras were notorious for forever running fans. They all shared the common component...Fan timer control unit...the usual culprit. Now fan controls are integrated into the PCM. Maybe when you had your trans put in they installed a new PCM. It is part of the tranny replacement. If the PCM has different parameters for fan control...this maybe this is where your deviation lies.
Aug 15, 2019 12:58 PM
01CLOwner
Oct 9, 2015 01:07 PM
F-C
Motorsports News
14
Sep 28, 2015 12:54 PM
Sep 17, 2015 09:01 PM
NSolace
Sep 3, 2015 08:02 PM
