Engine damper Kit?
What about your post regarding the fluid question (ATF-Z1 vs. DW-1)?
Is there an issue you are trying to diagnose/fix?!
I have almost 80k on my warranty replacement and I just did the second change in the 3x3.
The DW-1 seems to be a marked improvement.
I am going 3000 miles between changes during the 3x3 and the trans shifts better already.
Former Sponsor
Ingalls Engine Torque Damper ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
http://store.excelerateperformance.c.../i-389457.aspx
It comes with instructions too.
http://www.ingallseng.com/Instructions/93055.pdf
2003 TL-p
Ingalls stiffy is great, adjust it to a stiffer setting with more preload and it takes care of almost all the movement in the motor mounts without vibrations for me.
2003 TL-p
I can tell you from my experience the TD didnt do anything until i adjusted it to a stiffer damper setting, and added more preload. what ever it came set from ingalls was too loose.
![Pimp](https://acurazine.com/forums/images/smilies/pimp.gif)
09-15-2015 06:44 PM
oyayjoe
09-12-2015 04:40 PM
