engine codes and dash lights...
Old Sep 14, 2014 | 11:34 AM
TLinMN's Avatar
7th Gear
2003 tls 289,000 miles.
On Friday the engine light came on along with the vsa and triangle. I pulled the codes: P0300, P0302, P0304, P0305, P1399, and P1740. All codes except the last one are misfire codes. The P1740 is a code for: 4th pressure switch failure. The transmission in the car is not the original one. It was replaced at around 90,000 miles. I bought the car from a friend and have the service records showing it was replaced (not an oil jet kit add-on). The transmission fluid is fine, the car has never had any shifting issues. I replaced the switch this morning but haven't cleared the code(s) yet. I drove the car and within a few 100' the lights came on. The engine light will stay on while driving until I press the accelerator (not hard at all, but steady) and then the light starts flashing. Once I let off of the accelerator, the light goes back to constantly on. Once again, if I press the gas it starts flashing again. The engine seems to be rough (shake) under acceleration and above 40 or so mph.
Any suggestions? I purchased a new coil and plan on testing that next. Are the misfire codes and the transmission code a related issue?
Old Sep 14, 2014 | 02:53 PM
3.2TLc's Avatar
Try to resolve the "misfire" conditions first. Maybe just a bad coil.
Is the "D-5" indicator flashing also ?
The P1740 may be a wiring problem or faulty 4th gear pressure switch.
Check for a short to ground, poor connection or open wire to PCM.
Old Sep 15, 2014 | 12:08 PM
01tl4tl's Avatar
sounds like a coil at least- do the power lead connector to coil removal and see if engine rpm drops- if not its the bad coil!
reset ecu the easy way to clear codes= open passenger front door- remove access panel on end of dash- remove CLOCK fuse for a minute and reinsert- no kidding
its the secret ecu backup power
must be done after coil swaps or install of new coil
ck the spark plug at the bad coil for crud buildup
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
elietania
4G TL Problems & Fixes
Sep 5, 2015 06:52 AM
