Engine code P1607
Old Mar 12, 2007 | 08:41 PM
S1CK TypeS's Avatar
B A N N E D
Engine code P1607
well my engine light came on after my dom unit and dvd install. I had the code read and it said
P1607
manufacturer contrl
aux imput
aux output
can someone tell me wht this means? did i just screw myself over and am i gonna have to dump mad amounts of money at the dealer to fix it?
Old Mar 12, 2007 | 09:20 PM
Tom Blasing's Avatar
is the Mighty Favog
Granted it's another forum but this link may help.
Old Mar 12, 2007 | 09:27 PM
Malayalee King's Avatar
ഥഎണഡഏ Fellas Inc.
did you check all your fuses?
Old Mar 12, 2007 | 09:32 PM
S1CK TypeS's Avatar
B A N N E D
thanx tom..
now tht i think about i accidentally pulled the starter signal fuse plugged it back in and turned the car on. any chance that this could have set it off? my car seems to be running fine i drove it all day yesterday and today
Old Mar 12, 2007 | 09:36 PM
ഥഎണഡഏ Fellas Inc.
just check them all with a fuse tester or you can look at them too and see if they are broken. i would do this with my battery disconnected (negative) to rule out blowing more fuses lol...
my abs and tcs lights went off last week (by themselves) -- now my maintenance flashes and SRS stays on haha (i pulled srs out a couple of times -- long story)
g luck
Old Mar 12, 2007 | 09:38 PM
S1CK TypeS's Avatar
B A N N E D
thanx bro ill check them. i gotta an opointment with the dealer tomm lets see wht they gotta say. do they need to reset the light or can autozone do it if the fuse is the problem or will it go away on its own if i fix it?
Old Mar 12, 2007 | 11:02 PM
ഥഎണഡഏ Fellas Inc.
better see what dealer says -- use warranty while you can
Old Mar 13, 2007 | 08:54 AM
S1CK TypeS's Avatar
B A N N E D
they'll be like u caused this so u pay
Old Mar 13, 2007 | 09:24 AM
ഥഎണഡഏ Fellas Inc.
diagnostic free??
Old Mar 13, 2007 | 09:30 AM
fsttyms1's Avatar
Did you try resetting the ECU to see if they come back?
Old Mar 13, 2007 | 10:25 AM
S1CK TypeS's Avatar
B A N N E D
i took the battery out left it for like 20 mins and then put t back on and its still there.
diagnostic is only free if its not my fault, the service rep kinda fucked up my world. he said that P1607 is the tranny code and that since i have a aftermarket intake the light could be caused by that. in which case its my fault. i know this is bull shit but after my OE spacer install went wrong i had to use some liqud metal stuff to seal my TB till my OEM gasket came in the mail. I'm thinking that this is what set off the code and im gonna install my gasket put my oem intake back in and take it to a different dealer.
Old Mar 13, 2007 | 12:31 PM
S1CK TypeS's Avatar
B A N N E D
well the guy did a code check even tho i said no and he told me the transmission computer was bad so they ordered a new one. everything is covered under warranty thank god.
Old Mar 13, 2007 | 12:35 PM
ThreePointTwoTeeEl's Avatar
3.2TL
good.
Yikes
May 3, 2021 04:29 PM
ghuns
Sep 16, 2015 04:26 PM
datadr
Sep 12, 2015 09:12 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
