EGR port help
EGR port help
So this weekend I decided to clean my EGR port (to boost my mileage)
and silly me I forgot to get the spray carb cleaner.
I was under the impression that i would just scrub it off with like a flat head screwdriver or a metal brush or something. Obviously this did not work as well as i thought.
Is there anything else around the house that i can use to clean my EGR port?
Ahh sorry i for got to mention it was the 4th of july holiday and all the shops were closed.
I just used a flathead screwdriver and scraped off what i could.
So never mind
also did anyone get a TCS CEL and maintenance required lights on right after they did this?
should i be concerned?
So never mind
you knocked stuff loose, didnt get it out, and freaked out a sensor
do an ecu reset by pulling the CLOCK fuse on passenger end of dash
See if they come back
deep creep/seafoam, solvent, carb cleaner all work well to liquify the carbon
Neighbors often have a can!!
get 3 cans to do a good job
labeled CLOCK its also the secret backup power for the ECU
open passenger front door and look at end of dashboard- remove fusebox cover-
note location of clock fuse on diagram and remove with the provided tool
when you disconnect the NEG or black battery cable you have to input the radio security code and sometimes redo seat or other presets
with the fuse method you do none of that!! and it takes less than 1 minute of fuse removed time
as far as we know: it clears the ecu instantly on loss of power,, but leave it out 1 minute to be sure
works every time!!
works every time!!
gabru: many things you thought,, dont apply to the TL
It has some trick systems you need to understand
everyone needs to register with acura care, its free and can download an online owner manual for your car
http://owners.acura.com/registration...istration.aspx
also reg at acura care and ask if all recalls are taken care of
the airbag inflator one keeps adding more VINs to the list of covered cars needed to get fixed call 1 800 382 2238x5,,both those need the cars VIN
Wow thanks guys honestly
thanks i got my radio working again and have registered with them and learned that my trans was replaced in '05
about the airbag the lady i talked to told me that unless i have small children sitting upfront (as a college student i hopefully never have this issue anytime soon)
ALSO: i found out that if you hold 1&6 on your presets and THEN turn the power on the serial codes are displayed, so i didnt need to have to dig in and tear apart my car
radio: certain years are that way- you lucked out
register with owners.acura.com and store the codes there- safe and free
airbag- you are part of the recall or you are not!! (keep cking as the vin list keeps growing)
my understanding is its driver side inflator speed is too fast
Maybe where she's from,,, they let kids ride on your lap!! (was Britney Spears working?)
did they say trans replaced or recall taken care of?
its not very often the 800 has info on replacement!
look at your trans from above- see the bolt heads with blue paint everywhere?
yes=waranty replaced trans
no blue paint on bolt heads and oil jet kit on top of trans= OE unit with recall installed part in place
some trans were changed under warranty at recall inspection due to heat problems found
so you do have a warranty replaced trans--thats good!
Registered Nonmember
Question - I have red paint on the ATF bold, not blue. The transmission was replaced under the recall around 2005. Is there any significance to the red color or were they just out of blue paint?
where exactly is the red paint--on the refill bolt, top center of trans?
Blue paint is found on the bolt heads of bolts that go thru the trans and several that hold brackets to the trans are blue as well
blue means acura warranty replacement unit
are you certain it was replaced at the recall ??
(if certain heat damage was found they did replace many then)
OR
just had the oil jet kit installed in the filler hole-top center of trans
THAT WAS THE ACTUAL RECALL
OR
InFaMouSLink
10-30-2015 09:43 AM
