EGR port cleaning
Old Dec 3, 2011 | 07:11 AM
edesoto's Avatar
Question EGR port cleaning
So I decided that I would clean the EGR port today. I have done everything as per the directions on port cleaning in the DIY section. So far no problems...except that after you take the manifold off the engine, the engine part of the intake is just as dirty as the manifold, including the EGR conduct!
How to clean that?
Thanks!
Old Dec 3, 2011 | 08:47 AM
sammy95's Avatar
Ehh... I sprayed brake cleaner down there. I suppose I should have sprayed it, then used shop air to blow the dirt out.
Old Dec 3, 2011 | 08:48 AM
sammy95's Avatar
Oh for the EGR, I think you need to remove the EGR, then maybe a metal brush and cleaner down the tube.
Old Dec 3, 2011 | 10:15 AM
edesoto's Avatar
Is it ok to just spray it with carb cleaner?
But how do you rinse all that crap from out of there?
Old Dec 3, 2011 | 11:21 AM
01tl4tl's Avatar
the manifold is removed from the engine - so rinsing is easy
for the engine block side, have a shop vac running.. pointed at the crud you want to get off
Use screwdriver or scraper to poke it loose and vac up
better to remove.. than drop or blow crud further into the line
doesnt have to be perfect
Old Dec 3, 2011 | 11:39 AM
edesoto's Avatar
Got it 01...thanks!
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
