EBC GreenStuff or RedStuff
Alright so I have a 2003 TL-S. Have 127,xxx miles on the vehicle. I am the third owner and have had the car since May 2009. It is time for breaks to come off and put new rotors and pads
I've decided to go with the EBC Ultimax slotted rotors in the front and keep the OEM rotors in the back. Im also upgrading to SS break lines.
Only one thing....
REDSTUFF OR GREENSTUFF!?!?!
Ive been doing my research for the past 3 months and ever site says something different and conflicting answers.
So i do understand that that RedStuff are "track" pads that are ceramic based and will emit less dust. And the Greenstuff are organic based and emit more dust but are recommended for daily driving.
I live in Sacramento, CA so we have dont have extreme weather conditions. Just rain in the winter and heat in the summer. Never gets colder than 28ish degrees or hotter than 110. I would describe myself as an aggressive driver (2 tickets in the past 3 months :/...im in need of a radar lol) , I do an even amount of city and highway driving. With my more agressive driving than a typical driver would I benefit from RedStuff? they are also a bit cheaper.
Like I said theres lots of conflict information on Green vs Red so id like to hear what you guys got on your TL and your reccomendation. Im looking to place my order today since ive been needing breaks for a couple weeks.
So GREEN OR RED?!
Only one thing....
So GREEN OR RED?!
Honda+Blue=My garage
I have greens and love them for noise and dusting is minimal.
Reds as ceramics have more noise (as do most track pads)
I would give :thumbup: to greenstuff
2003 TL-p
im running red stuff, they perform great and the hotter they get the harder they grip, minimal dusting. they do make a little noise, but it doesnt bother me.
redstuff is fast street use not track use, if you are aggressive you will benefit from the added performance when they get hot. also red stuff works great in the rain.
dont cheap out on the rear rotors, get ebc red and rotors on the back too, you wont be sorry.
2003 TL-p
also i can do 6, 60-0 stops in arrow and have no fading, they bite harder each time. very powerful brakes. make sure you follow bed in procedure exactly as directed from EBC!!!
i have the dimpled and sloted rotors and red stuff on all 4 wheels.
x2 on EBC's redstuff pads. It's a little wetter up here in the Portland area than you are in SF, but I'm a pretty aggressived driver like you. I've been running EBC's dimpled/slotted rotors front and rear, with the redstuff pads and Goodridge SS brake lines for about 18 months, and they've been great. Low dust, awesome stopping power in the wet and dry. 100x better than stock. You won't be disappointed with the redstuff pads in any way.
bringin lead
are you running SS brake lines?
Just read your post again. You found Redstuff pads cheaper than Greenstuff? Everywhere I looked the Redstuff were a few bucks more. Where did you find the lower RS prices?
the legend calipers are the awesome upgrade!!
SS lines should be on the car!
ck out mrheeltoe for racingbrake brand , and excelerate for ebc and rotora,, other good choices
with redstuff it puts me at a higher total and with a coupon code its a bigger discount, ended up like 5 bucks cheaper, nothing major
And thanks guy I really appreciate the info. Im leaning more towards the RedStuff now
Bonki' Ehrite!
I wanna get new pads, I'm gonna go with redstuff...However, I just put new rotors on a few thousand miles ago (auto parts blanks)...
If I sand the pad material off of the rotors would it be okay to use the red stuff with the auto parts blanks?
I didn't wanna start a new thread, so I figured I'd ask here.
2003 TL-p
^ red stuff has a break in coating that is more abrasive so as long as the rotors are not wapred (check runout with dail) you should be ok. the break in coating will create dust, but it wears off fast. EBC recommends using their rotors with red stuff pads. i am unsure how they will perform on blank rotors. red stuff pads my require slotted rotors but i am not sure on that, dont quote me. still running red stuff pads on regular rotors is overkill since the pads are designed to handled much more heat than those rotors can handle. just bedding in red stuff pads may be too harsh for blank rotors which requires 6+ hard 60-20 brakes in arrow, red stuff pads need to get very hot to bed in correctly. for auto part blanks id go with green stuff, its not worth putting red stuff on blank pads.
2003 TL-p
if your into aggressive braking id recommend dimpled and slotted ebc rotors, beware they make a little noise but its not crazy. i am currently running them for a while and they perform beyond my needs.
2003 TL-p
check out our vender xlr8, i think he is running a deal for Azin members on stoptech brake sets. its like a 550 buck set for 390. also check out placeforbrakes . com for deals on EBC stuff.
My Setup with EBC Brakes!
I Havent Used either but the Yellow Stuff + Dimpled/Slotted Rotors from EBC and DANGGG!!! The thing sure Stops!!
This is my Setup
I Painted the Brand New EBC Rotors with High Temp Paint to cover the possible parts where they could get Rusty
New Rotors Vs OEM
FRONT:
REAR:
New Goodridge SS Lines Vs Stock Ones:
Installing:
Rear Rotor + Draining Brake Fluid, Yup i dont have Speed Bleeders
Wheel On:
After 10Miles:
The Results are Incredible 110% Recomended Yellow Stuffs havent Tried the Red or Green but Yellow Stuff Rocks.
My Only Complain is that they Make ALOT of Dust and Screams a Lot during light breaking, But After they get hotter holy! They Stops for Sure... Hope you decide to go with EBC!
This is my Setup
New Rotors Vs OEM
FRONT:
REAR:
Installing:
Wheel On:
After 10Miles:
2003 TL-p
^ niceeee set up, yellow stuff is suppose to be superior to red stuff in cold and hot performance.
really nice job on the extra rust proofing paint job, extra thumbs up
MechEng
my yellow stuff pads are wearing out after only 4000 miles when i took my car in to the dealer a couple months ago they said the pads only had like 50% life left. i didnt really believe them but i can tell somethings up with the pads.
i followed EBC's bed in procedure too. im not sure what i did wrong. i definitely feel reduced brake performance. still no fade, but definitely increased braking distances. obviously distances will increase with wear, but not after 4000 miles. ive never even tracked the car.
oh and they still squeal like a wild boar
i think i may go with racingbrake et300s next time around....
Thanks gold2003tl!!! Your ride is one of my inspirations... Hope you Still have it, Im Planning to Own my TL-S forever so Many Mods on my List to Complete tough right now my Budget is on the NSX.
@03tlsNBP
Thats wierd i have like +10,000K on them and they seem to have a little more of 50% of Life.
@03tlsNBP
2003 TL-p
whoaa 03tLsNBP, 4k miles? i have like 6k on my red stuff and they basically have no wear at all, i am expecting to get long life out of my pads. my yellow stuff is just really high performance and goes away fast. red stuff barley dusts so they cant be wearing nearly as much i suppose. maybe you should give red stuff a try.
2003 TL-p
@03tlsNBP
@03tlsNBP
Re:
I Just bough it! it was laying around in some random house i found it and the dude sold it for 15K with Salvage Title.
Its a 2001 Model with the C32B + 6Spd MT.
My TL on the Back lol, its the day i came for it....
Right now its BONE STOCK so im starting to save to have it Moded right away...
PD: Sorry for bad pics, My iPhone camera hates me.
MechEng
gahhh the NSX is one of my all time favorite cars
yeah idk whats up with my yellow stuff. maybe i drove too hard. or maybe i just expected too much out of them. who knows. the red stuff was backordered when i bought them so the place sent me yellow stuff instead at no extra charge. so im not too angry about it. maybe i should have waited for the red stuff haha.
rockyboy
01-25-2016 06:00 PM
