Dynomat.....heard of it???
Old May 20, 2001 | 02:14 AM
Guest
Guest
Posts: n/a
Post Dynomat.....heard of it???
Hi:
I am curious..Any of you guys heard of dynomat? Anyone installed it on your TL=S?
If yes, where and how much? is it good?
I might want to get it.
Old May 20, 2001 | 02:42 AM
sneuxstorm's Avatar
Post
its called Dynamat ( not Dynomat, I think that was what JJ Walker used to say on ' Goodtimes' -odamn I'm old...). Its sound deadening material. It is used to reduce the resonace in cars by higher end audio installers. It works fairly well when used right.
Photoshop Chop Shop
Vegetarians Taste Better
Old May 20, 2001 | 03:39 AM
Guest
Guest
Posts: n/a
Post
heehee..sorry =(
anyone used it before?
Please let me know the result. Thankx.
Old May 20, 2001 | 12:28 PM
PeterUbers's Avatar
Post
Someone I knew dynamat-ed his GTP after installed nearly $3K of audio equipment, including custom 6x9's for each door (SEDAN) and two 12" subs in the trunk. Trust me, w/ the build quality of this particular GTP, it sorely needed it --> the dynamat not only improved acoustics (for someone w/ a poor musical ear such as myself), but also deadened road noise a little, and totally cut out plastic vibration. It was QUITE a task installing it, but he's really into car audio, so that's his sort of gig.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by PeterUbers on May 20, 2001 @ ]</font>
Old May 20, 2001 | 12:38 PM
Road Rage's Avatar
Not a Blowhole
Post
It is good stuff - the best is sorbothane, which is essentially a very lossy polymer in solid form. Many different thicknesses available. It has the highest absorption factor I am aware of.
We use this widely in the high end audio design world.
It is expensive, but the best - try McMaster-Carr for sourcing.
