Drivers side window wont go up
So I just replaced the driver side regulator in my 2002 Acura TL. When I originally put it all back together none of the windows would work at all. However after about one hour the passenger windows started working the passenger side window will work when it's operated from its own switch however the driver side window still doesn't work and when I try to put the passenger window up and down from the master controls all the passenger window does is Click Can anybody please help me and resetting it won't work because in order to reset it you have to be able to put the window down well I can't put the window down it's stuck about halfway up please help me if anybody knows what to do thank you
Hi Brett, Welcome to Acurazine.
I would do a search for the 2G "1999-2003 tl service manual" on here if you don't already have it.
Sounds like an open ground or (more likely) faulty power window relay; the book will describe tests to run to allow you to troubleshoot and pinpoint exactly.
