Driver side leak
Old Aug 17, 2017 | 04:59 PM
OTHREETLS's Avatar
Driver side leak
I searched and read some threads but can't find a concrete answer.
I have a 2003 TL type s. As of late, my driver's side is wet under the carpet. I can't tell where it's coming from. Sunroof drain was cleared a few weeks ago and water was coming down just fine. It rained a couple of days ago and I went to my car 30 minutes after it started raining, and it was damp as hell down there.
Lifted the car up today and there's a little hole in the body that might be causing it, but I'm not sure. How could the water from rain go UP from under the car while parked? Also, that much water? I feel like it's gotta be coming from somewhere else, but don't know where.
So it gets wet, while parked, and I can't figure it out.
Old Aug 17, 2017 | 08:17 PM
bbsitum's Avatar
Connect that drain pipe and use some ring so it will not happen again. It is up left from yours foot at car body. Googable. I would not botter to post pictures.
Old Aug 17, 2017 | 08:54 PM
OTHREETLS's Avatar
Connect what drain type? Sorry, I don't understand..
Old Aug 18, 2017 | 03:27 PM
bbsitum's Avatar
https://acurazine.com/forums/second-...r-side-949536/
Go from there and google for photos at yours own. There is dosen of it at Internet.
Old Aug 18, 2017 | 03:34 PM
horseshoez's Avatar
Latent car nut
I've never tried to clean the drains on a 2G TL or a 6G Accord (I assume they're very similar), however, I have heard cleaning the drains, if not done carefully can lead to the top half of the drain pipe becoming separated from the bottom half. When this happens, water usually pools in the front footwells.
Question, did your Driver's side carpeting get wet when the car was parked before you had the drains cleaned?
Old Aug 18, 2017 | 03:35 PM
bbsitum's Avatar
I would just check with hand if is pipe disconected or not. 10 seconds job. Or if he need to see it use mirror and flash light. Easy too.
