double din kit for 2g TL
-E-K-S-O-
i've been searching and searching on this forum for a definitive answer. so far these are the results that i've found...
-purchase one from a vendor on acurazine
-make one using a metra kit
-find one on the classifides
i can't afford nor can i make a doulbe din... my question is
-can you use the 2002 Accord V6 doulbe din kit?
I made mine, its really not that hard. Get a cheap single din on ebay. Now all you have to do is cut the bottom part out. I used a dremel which you can easily buy at target(which is where I got it). And if you want to be cheap, return it afterwards. Either way, the kit will costs you 10 bucks, cut it yourself, and call it good
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
