Don't fix what's not broken?
I've hit 214K (miles) and still climbing ('00 TL). I expect to keep the car for at least another year then replace it possibly with a new TL-SHAWD
I have never replaced the following components (if it's not in the list, assume I've replaced it):
I know I can get a pair of 4500K Xenons on the cheap to replace my aged pair and I should notice an output difference; I probably will.
How about the Oxy sensors and Struts? Worth doing or only worth doing if something goes bad?
I'm curious to get your input on the list; basically, have I just become used to bad handling/performance over the last 11+ years...
Thanks!
.I have never replaced the following components (if it's not in the list, assume I've replaced it):
Thanks!
I'm rocking original struts and 02 sensors as well. Nothing wrong with that. If your fuel economy is fine, I wouldn't worry about the 02 sensors. No harm in changing them after this long, but mine seem to work fine. A little seafoam will keep them in shape as well.
As for the rest of the suspension, I also have had zero problems. It almost worries me that after 180k, I've had to replace nothing in the suspension. I'll probably just replace things as they break now.
pretty sure you would notice a large improvement if you replaced the struts, I replaced my struts and springs a while ago. the other stuff not a big deal unless it does break or you throw a code because of the sensor. I got a pair of 5k bulbs off of this site and the color was much better vs stock but the bulbs didnt work good at all so I put the stock ones back on and they are still working.
I am at 181k miles on my '99 and have only had to replace the starter - of course it was Friday after work and it was about 100 degrees outside, my cell phone was dead and the office was already locked so that was a fun Friday! I still have the original brake fluid even...
I am in the same boat as you. everything works 100% except the transmission needs some attention. I am going to clean out the shift solenoid screens to hopefully buy some time. trying to decide if it would be worth spending $3000 give or take and keep the car for a few more years
ou- please flush your brake fluid TODAY!!!
every 2 years is the suggested, more often (yearly) if lots of moisture in the air, or you drive the car hard
special bleed/flush order on the TL is: driver front then clockwise around the car
LF RF RR LR
its due to ABS plumbing
LF RF RR LR
Sev
we dont have plain xenon bulbs- they are HID = special bulbs
www.hidextra.com has good products at low price and they support azine!
have an alignment shop ck the ball joints- tie rods etc.
that noise is coming from something!!
a seafoam treatment= vac port and gas tank, or twice thru gas tank 1 can @half tank
if you dont like to do vac port method--
and new plugs if more than 70kmiles on them
New front O2 sensor never hurt, it may be 1mpg improvement but that adds up fast!
Thanks!
Thanks!
nothing says you cant replace a front O2 sensor now, they dont caost that much for Denso, the OE-- plug and play brand
it can work poorly for a long time before actual CEL and failure
that 1-3 mpg adds up fast at 4 bucks a gal
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
darksky
Sep 5, 2015 03:11 AM
