Dog Chewed Passenger Seat Wires?
Old 09-16-2012, 08:45 PM
AcuraHonda415's Avatar
Hello my dog chewed up some wires underneath the passenger seat, can anyone tell my what they are and if they're important. Thanks!
Acura TL-S 2003
Wires Affected: Green/Blue, Green/Red, and Black.
Old 09-16-2012, 08:46 PM
Sorry i'm a new member the picture isn't working, here's the link.
http://imageshack.us/photo/my-images/442/photo1wn.jpg/
Old 09-16-2012, 09:28 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Most likely the Seat Position Motors...
For you:
AcuraHonda415 (09-16-2012)
Old 09-16-2012, 09:43 PM
3.2TLc's Avatar
How did the dog manage to get underneath the seat to chew on the wires ? Must've been in hot pursuit of a mouse or rodent ! Did a fuse blow ? As Skirmich suggested, check the logical things such as the power seats and heaters. Is your dog ok ?
You may need to remove your seat for a better doggy view to assess the actual damage
inflicted by the hungry dog. It may be as simple as locating the other remaining side of the chewed wires, clean up the ends and properly splice back together the matching wires.
In the meantime, no more rides for Rover unless in a cage.
justnspace (09-17-2012)
Old 09-16-2012, 10:15 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
NOTE!!! failure to remove battery neg cable before messing with any wires under seat MAY result in false SRS light,,see DIY section for reset procedure
some of those are occupant position detector, airbag triggers,
plus seat motor and heater as noted above
Whats NOT working on that side now?
Old 09-16-2012, 11:34 PM
So far the all the motor seat adjustment seems to be working. The seat warmer seems to be broken. I'm looking at youtube diy seat removal, it seems straight forward with the right tools. My SRS light has been on, I'm not sure if this was the cause, since I found the chewed wires today while cleaning the car. All fuses are good. Dog is fine.
Here is a picture of the little devil that made this mess...
http://imageshack.us/photo/my-images/23/photo2zx.png/
Old 09-17-2012, 04:54 AM
6G TLX-S
Edward'TLS's Avatar
Received 1,141 Likes on 816 Posts
Make sure your dog doesn't chew through A/C power cords inside the house, which may be fatal.
Old 09-17-2012, 09:08 AM
Unregistered Member
Karanx7's Avatar
At least he wouldn't chew on any more wires?
Old 09-17-2012, 09:43 AM
3.2TLc's Avatar
Originally Posted by AcuraHonda415
Dog is fine.
Ah come on Karanx7, where's your heart ?
That cute 'lil guy is just teething !
Old 09-17-2012, 11:53 AM
damaged442's Avatar
I thought I was going to see another thread saying "Dog needs new home!" lol Hope you can get it back together with no issues.
Old 09-17-2012, 07:24 PM
01tl4tl's Avatar
ck our diy section for more help on the seat removal,,probably in the `seat heat` section
pass seat only gets lower/butt heat, no back/upper section of seat heat due to srs sensors
wires fixed and srs reset,,hope for the best!
rockyboy
12-06-2022 02:29 PM
pistacio
09-26-2015 09:45 AM
mikeytown2
09-21-2015 12:41 PM
scionxb3003
09-06-2015 12:19 PM
kareshi
09-03-2015 03:38 PM
Quick Reply: Dog Chewed Passenger Seat Wires?
