Does NE1 know what the minimum rotor thickness R?
Old 06-22-2007, 06:30 PM
Mike390's Avatar
I've changed my rotors several times now and each time I bought new rotors but kept the older ones. The old ones are still in great shape and finally found a place that can turn/machine them for short $$. Does anyone know what the minimum thickness is?
Please don't respond saying buy new rotors and thanks in advance.
Old 06-22-2007, 06:56 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
That should be something that the place that turns them should be able to look up. I dont have my manual here to look up.
Old 06-22-2007, 07:37 PM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
Its stamped onto the center hub of each rotor-
use a digital caliper to measure thinnest point and then allow for shaving smooth beyond that
Most rotors of quality can take 1 resurfacing- the OE parts- not so much
Ask the shop what they do as final pass or surfacing
Some do another slow speed cut smooth while others add a cross-hatch cut to help
bed the pads right away
Remember- you get what you pay for!
Old 06-22-2007, 08:21 PM
acutee's Avatar
As far as I know you can only turn it once. the second time it will not meet the specification to be considered safe.
Front Disc:
Standard 27.9 - 28.1mm
Max Refinishing Limit - 26.0mm
Runout Service Limit - 0.10mm
Rear Disc:
Standard 8.9 - 9.1mm
Max Refinishing Limit - 7.5mm
Old 06-23-2007, 08:18 AM
Mike390's Avatar
Cool thanks
08_UA7_Gr33k
02-11-2016 02:17 PM
ExcelerateRep
10-14-2015 08:20 AM
4drviper
09-23-2015 07:42 PM
Quick Reply: Does NE1 know what the minimum rotor thickness R?
