does the car shake if the engine mount is crack?
Old May 26, 2010 | 04:01 AM
gtreric's Avatar
7th Gear
i know that my car shake when i speed up near the 30mpg to 45 mpg.
and i know my engine mount is crack, is it because its crack that makes the car shaking guys?
Old May 26, 2010 | 06:11 AM
Sperry's Avatar
2000 TL Black on Beige
Probably, yes.
Also wheels out of balance make shake. My "rebalanced" wheels were not balanced with any bit of care, and the car still shimmied.
Bent rim with make shake.
Old May 26, 2010 | 08:06 AM
OEMAcuraPartsTim's Avatar
Former Sponsor
I agree with Sperry. I would rotate the tires front to rear first, and see if the shaking stops.
Old May 26, 2010 | 09:11 AM
01tl4tl's Avatar
When a vacuum boosted mount breaks it causes what?? a vac leak and poor running!!
Broken mounts should be replaced now
Old May 26, 2010 | 04:55 PM
gtreric's Avatar
7th Gear
alright thx guys, i will do tire rotate in the weekend see it still shakes
Old May 26, 2010 | 05:23 PM
fsttyms1's Avatar
Old May 27, 2010 | 02:18 AM
01tl4tl's Avatar
I would replace the broken mount and fix the problem
Unless you recently hit a pothole to hurt a rim,,,look at the real problem- not what you can waste time by trying the tire swap
If you had said `right after I rotated there is a shimmy,
and btw I have a broken front motor mount`...I would suspect rim problem then mount
Old May 27, 2010 | 02:20 AM
01tl4tl's Avatar
rim balance issue would not show up at 30-45 mph as OP stated
It would be all the time- you will know if it happens to you!
Old May 27, 2010 | 10:08 AM
JDTL-S2002's Avatar
hands bends in my rims. got them bent out and balanced 2 days ago... $150!!!
but, they wheel wouldn't shake until about 48 mph til 60 mph. wheel no longer shakes but still have shimmy in the SEAT. Ughhh
Old May 27, 2010 | 11:00 AM
01tl4tl's Avatar
ok then- lets say a minor rim issue wont show up till the higher speeds
I had some that were really bad and you knew it
BUT the op has known broken motor mount- Im guessig front side (front of car/l side of engine but called front mount)
get the car moving and you may get shimmy and shake!
JD- ck the motor and trans mounts plus steering parts for you shimmy
If the rims got bent there was other hidden damamge...
was it from a big curbshot or pothole city is where you reside?
Old May 27, 2010 | 01:02 PM
my.daily'tl''s Avatar
Always Working In
Broken motor mounts will cause a rough idle too. I'm with everyone else you may have suspension issues too but motor mounts first!!
Old May 28, 2010 | 12:56 AM
JDTL-S2002's Avatar
they were VERY minor bends but bends none the less. wheel is smooooth now but i still get seat shake around 45-60. maybe ball joints? or tie rod ends? could be numerous things
james357
Feb 13, 2016 02:37 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
datadr
Sep 2, 2015 06:46 PM
