does anyone else notice this...
Old Apr 4, 2002 | 12:18 PM
avenutolo's Avatar
Question does anyone else notice this...
I notice that in the my '99 TL that the outside temperature gauge seems higher than it actually is. For example, if it's around 40 outside, my temp reading on the dash might read 46.
Is this normal?? Does it affect the climate comntrol system?
Any feedback is highly appeciated!!
Old Apr 4, 2002 | 12:20 PM
copland007's Avatar
Having Fun?
Yup, mine was off by a couple of degrees. Check out this post:
http://www.acura-tl.com/forum/showth...st+temperature
Old Apr 4, 2002 | 12:30 PM
BlackShadow's Avatar
O.G.
Does this happen when the car is parked? If it is, then just drive it for a few minutes and the temperature should go down to match the outside temp.
Old Apr 4, 2002 | 12:36 PM
TypeSDragon's Avatar
Loving my 08 TLS!
Look at your owner's manual, there is instructions to change the temperature settings.
Old Apr 4, 2002 | 12:51 PM
songoku's Avatar
BlingBling INSPIRE 32V
Yes, you can adjust the temperature setting by pressing RESET & SELECT buttons while you're in ignition.
Old Apr 5, 2002 | 02:57 PM
FTM-1's Avatar
Mine has been correct for the past 2yrs of owning the car.
The day I got my car 12/28/99 it was 32 & 31 degrees this was the coldest day that we had sofar. Every radio station was givng the temp that day thats all they were talking about. Since having the car we have had days in the single digits & it has been correct. But always remember that the car need to be moving for a good reading. The outside temp guage has nothing to do with the climate control system. The car has a sensor for the inside temp.
Old Apr 5, 2002 | 03:08 PM
That works for the temp. too??? What doesn't it work for?
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
jpadilla
3G RLX (2013+)
Sep 27, 2015 07:53 PM
urbtsx
Sep 27, 2015 09:40 AM
Brandle34
Sep 23, 2015 07:20 PM
