DIY Help..Lost..Door LEDS
Old Apr 1, 2007 | 05:09 PM
Davinci27's Avatar
Ok I'm lost. So I was following the Door Handle DIY: https://acurazine.com/forums/showthread.php?t=154298
I wired the front drivers and Front passengers to the door lights, as instructed. Now I'm stuck with the rear passengers(2) door. The drivers rear door I'm suppose to run the wire all the way to the Passengers side fuse box, next to the glove box, but what do I connect them to? Same thing with the rear right side passenger door, what do I connect the + & - to? I tapped into the fuse box and connected it to the dome trigger wires on passenger window pillar.
I get lost after instructed to tap into the drivers fuse box....tap into the fuse box, ok, where do I connect the ends to?
If anyone has done this n can help me I appreciate it. Thanks!
Old Apr 1, 2007 | 05:43 PM
02TLSfan's Avatar
Prick of the month
After running the wire from the back driver's side to the passenger side fuse box, use about 10 inches of wire to connect the driver's fuse box to the wire you just ran from the back. This will give power to the back door and you only have to run one pair of wires across, the wires from the driver's side will connect both doors to the dome trigger.
Again use about 10 inches of wire and tap that into the passenger fuse box and connect the ends of it to the ends of the wire from the back passenger door and the ends of the wire from the driver's side. This will give the back passenger door light and make it easier to tap everything into the dome light.
When you run the wire down from the dome trigger, you will connect the positive and negative to the 3 positve and negative wires wrapped together. This should give everything power and a dome light connection.
Basically, make sure you get the power by tapping the fuse boxes and connect all the wires from the taps to the wires coming down from the dome light tap. If you don't disconnect the battery you will blow a fuse when the last connection is made, replace it with another 7.5 amp fuse, I am using a 10 amp temporarily but it is not needed. If you do blow the fuse, it is in the passenger fuse box, it's the accessory fuse.
I wish I had more pics of my install, I would take some real quick but my car is still at the dealership...another story...
Old Apr 1, 2007 | 08:56 PM
Davinci27's Avatar
Thx Got it to work, will post pics later.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
eastcoastguy
Sep 23, 2015 06:29 AM
scionxb3003
Sep 22, 2015 05:28 PM
