DIY heated seat, successed! cost only $3
So I attempted this fix today but ended up having an issue taking off one of the bolts (the right front). Looks like my socket was stripped so I gave up. I used a 14mm socket and didn't have anything smaller. I'm gonna give it another shot when I have the proper tools.
check the power at each seat wire connection to the heaters- its odd to have both seats fail
Its usually the driver seat bottem breaks a wire- right about where a mans wallet would put extra pressure in one spot
BUT
seat backs have been known to fail
Note: only the driver seat gets both butt and low back heat, passenger only gets butt heat...its a side airbag/sensors issue on passenger side
BUT
Has anybody done the passenger side? Is there anything special I need to do to avoid messing up the airbag or anything?
Do I need a certain size or shape of hog rings, or do I just need anything that will close?
post 151 says "Just cut the HOG rings with some good side cutters, then replace them when you're finished. Watch out for the pieces that can fly out when you cut them. Get new ones at an upholstery shop, or try a craft or fabric store."
I wasn't sure what was meant when it said "replace" them and to get new ones at an upholstery shop.
thx! I was going to do this yesterday, but the boss made me hit the honeydo list... at least the Yankees won!
seperate systems upper and lower iirc,,or you are the first to experience it
If driver side both are out- check the power to the seat first- could get lucky
If passenger seat- the butt is only part to get heat- side airbag sensor issue on passenger seat so no low back warmth for them
You can buy Hog Ring pliers and rings as said before, a few bucks, or use 2 pliers to open and re-close
They look like the round metal ring in a hogs nose ,,or some humans~~
the pliers-like tool squeezes them back together round
I have used both methods in the past
I didn't have the butt or back working on my car, I fixed the bottom and put it back together, and the back still doesn't work; so they are seperate systems...
I have nothing to back it up, but I think Acura just didn't put warmers in the upper part of the passenger seat; if the driver can have an airbag, lumbar adjust, and the warmer, why couldn't the passenger have an airbag and a warmer... unless is has something to do with the sensor used to turn on/off the airbag!
ok so I'm an electrical noob, but what I got out of this is that only the two connector wires, burn out because they have to much resistance and should have less...? so when swapping out the wires the only parts that need to be changed are the two connecting ones.
Please tell me if I'm wrong and if so what wires I need to make bigger.
Not sure what you mean by "connector wires". It's the element wire that burnt open on mine. You don't want to change the size of the wire as resistance in the wire is what generates the heat, which is what you want in this application.
BTW my repaired seat bottom element (last year) has failed again so I plan to replace the element w/ the honeycomb type like I put in the seat back.
nersh- you need to use the same size wire to replace the broken segment
Bad enough the connectors increase the resistance, dont make it worse!
The factory wire size is the right size, the problem is usually caused by a wallet..
I went around to a bunch of places, 38 gauge wire is incredibly hard to find. Correct me if I'm wrong but by going to a larger wire nothing will go wrong, other than that strand of wire won't heat up because it will have less resistance right? And since the only part I need to replace is just about at the joint between the ass and back, I don't really need heat there. So I should be able to add larger wire and more of it for less stress.
It's no where close to that small. Maybe around 20-22 ga. Get some wire strippers with the individual stripping holes and you can use them to check the size.
Mine (bottom element) has failed again & it's not because of a wallet because I don't sit on mine.
^My butt starts to fall asleep if I sit on my wallet..and mine's out too so it can't be from a wallet. I wonder why yours would go out again tho..hmm..did you use thicker wire and give it more slack?
Opened it up again. There are 2 rods that run across the seat bottom, under which the heater element is fitted. Both times it has burnt underneath the rod closest to the front of the seat. This time I replaced the element wires that go under that rod with larger wire covered with a protective sleeve. We'll see how that holds up.
My repair using 18 gauge wire is holding up great after my last repair and gets nice and hot every time. I don't put wallet in my back pocket anymore, just in case. Those aftermarket seat warmer doesn't look good in TL. Maybe in a Buick....LOL
how to check the power to the seat?
