DIY: 01-03 Civic fogs on 99-01 TL
Old 06-02-2009, 04:07 PM
  #81
ScottayHiFive's Avatar
Originally Posted by thinhthan
i wired up my fog light switch with a 03 fog light switch. everything works but my fog light switch dont light up. the green light on it works when i push it but the switch it self dont light up. i wired it with the red wire with yelllow light to the top and i skip the second and i put the solid red one to the third and the red with a black line in it to the fourth and the black to the last one
Naw mang it goes
1st Prong:Red w/ yellow line, 2nd Prong: Blank
3rd Prong: Red w/ black line, 4th Prong: Black wire
5th: Red wire
Old 06-02-2009, 04:19 PM
  #82
thinhthan's Avatar
ok ima go try that now. i thought you guys said any one the red wire thats why
Old 11-28-2009, 01:40 PM
  #83
I got the Shifts
phee's Avatar
finishing mine up today
Old 12-01-2009, 01:08 AM
  #84
2000 acura tl FPR
assclown's Avatar
Old 12-01-2009, 02:13 AM
  #85
Nice work! I love mines until you look at it closely haha cause I didnt mold it right. Are planning on putting hids in them or just using the bulbs it came with?
Old 12-01-2009, 11:41 AM
  #86
2000 acura tl FPR
assclown's Avatar
i threw away the bulbs that came with it when i got the package, i got 3000k kit. pretty damn bright.
Old 12-01-2009, 01:12 PM
  #87
Like a BOSS
Ep3moschini's Avatar
I will be doing this over the winter. I was half tempted to do a front end conversion just for the headlights. . . But I love my 01' front end so much
Old 12-01-2009, 01:31 PM
  #88
2000 acura tl FPR
assclown's Avatar
eh, i'd rather do projector retrofit but since this tree branch fell on my car and i have to pay the deductable, that project is on hold now.
Old 12-01-2009, 01:36 PM
  #89
Like a BOSS
I messed up when I posted "headlights" I was supposed to post "foglights"
I really want foglights
Old 12-09-2009, 12:20 AM
  #90
Always a Honda =Þ
JterrorC's Avatar
Helppppppp....
so i didnt have silicone but i had time to change my cracked old one...this is my 3rd set...sob...did it differently this time around...insight anyone...
before
after
behind
why doesnt the hid turn all the way to lock into place....jus a lil
my old fog were connected to the parking brakes...so i want to redo everything to hav a switch for it...but my wires arent the same colors...so confused....i read many of the post....started being helpful around the 50s den i got lost..
so heres what im thinkin....instead of using the cars fuse box....doesnt it already come with a fuse....
so i would jus need the switch rite...cant i jus throw away the grey connectors n jus use extra wires as an extensions...connect the fuse cable to the battery (like the amplifiers fuse)...
am i getting somwhere here?
also...what is the relay for?
Old 12-09-2009, 12:22 PM
  #91
Always a Honda =Þ
JterrorC's Avatar
somone help...my bumpers in the kitchen...i dont wanna put it on n hav to take it apart again..
Old 12-09-2009, 10:32 PM
  #92
No He Can't
6MTUA5's Avatar
The relay is for the switch
When the switch is switched from on to off the relay kicks in
You can wire it straight to the battery, or just try and find another constant source for power. Tap into whatever has constant power. You aren't going to the car's fuse bow for the fuse. You are tapping into the fuse bow to get power. The fogs should have a fuse of its own.
Old 12-10-2009, 04:10 PM
  #93
Always a Honda =Þ
JterrorC's Avatar
ight so i could figure out the damn switch...went to autozone got me this cool lookin touch switch....wired it up didnt work....wth....this is the setup....
Old 12-12-2009, 11:44 PM
  #94
Registered Enthusiast
emaka9's Avatar
very nice DIY.
Old 02-23-2010, 03:31 PM
  #95
DONZ3.2TL's Avatar
I picked up some fogs off of eBay and they don't fit into the pocket. I heard some people say they had to modify the fog light housing and some say it fit perfect. Can someone tell me which fogs they picked up with out modifying the foglight housing to fit? Thanks!
Old 02-23-2010, 05:52 PM
  #96
2000 acura tl FPR
assclown's Avatar
there aren't any, i used the 01-03 civic fogs and i had to cut away at the housing, you wouldn't be able to tell because the parts that i cut are behind the bumper. dremel is your best friend.
Old 02-23-2010, 08:51 PM
  #97
DONZ3.2TL's Avatar
Thanks bro! Just wanted to make sure before I start cutting away! I'm going to start this project tonight! One other question, did you mount your HID ballast in the bumper or on the frame?
Old 02-23-2010, 09:23 PM
  #98
2000 acura tl FPR
assclown's Avatar
i got the ballasts with mounting eyes in them, so i was able to bolt them to the frame. i don't like trusting double sided tape.
Old 02-24-2010, 03:05 PM
  #99
DONZ3.2TL's Avatar
Good to know, I have them fitted into my bumper now, and will do the wiring tonight after work. Thanks again, and I'll try and post pics after the install.
Old 02-24-2010, 03:41 PM
  #100
weirdxpsycho's Avatar
yay
Old 02-27-2010, 10:21 PM
  #101
DONZ3.2TL's Avatar
Mission accomplised! Thanks everyone for the great information!
Old 03-13-2010, 05:32 PM
  #102
Flagship Aspec
tc5280's Avatar
i have been trying to get a deep yellow look for my stock fogs. any ideas on what color temp to get. the two sets i have got are not achieving the color i am looking for.
Old 03-24-2010, 01:47 PM
  #103
twill220's Avatar
firewall
how can i get through the firewall w/o cutting metal for fog light install
Old 03-24-2010, 03:53 PM
  #104
DONZ3.2TL's Avatar
If you do back thru the thread you will see a detailed explanantion with a picture that shows where to push out the plug. It's located above the gas pedal.
Old 03-24-2010, 05:42 PM
  #105
Always a Honda =Þ
JterrorC's Avatar
3k n 2.3k ...or jjust get yellow lens fogs....and u dont need need...just use halogen
Old 05-24-2010, 07:43 PM
  #106
xplicitzTL's Avatar
i finally did this DIY after my school... everything went well and i had to cut the frame but no biggie thanks to dremmel. only problem im having is the wiring. i basically did everything i had to. I attached the red wire to the positive side of my battery. the only thing is i have a wire with a connector that says ignition. i did not plug anything in my fuse box. I have all grounds bolted where am i adding this "ignition Lgnition" wire. bought this off ebay thanks
mvidal6
ILX
11-14-2015 07:43 AM
Avenger411
10-11-2015 03:53 PM
rockyboy
09-29-2015 12:05 AM
rhdune16
09-28-2015 11:31 AM
ceb
ILX
09-27-2015 10:56 AM
Quick Reply: DIY: 01-03 Civic fogs on 99-01 TL
