Discharging headlight
Old Sep 4, 2006 | 08:54 PM
SwampGas's Avatar
/etc/car
Low beam is out...is there a procedure for discharging the headlight assembly or will it dissipate after a few minutes of no power?
Not a bad run...lasted 6 years with me having the headlights on all the time.
Old Sep 4, 2006 | 09:33 PM
Rpappi's Avatar
DRINKING HAS A ME PROBLEM
that isnt a bad run
Old Sep 4, 2006 | 11:01 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Just disconnect the battery.
Old Sep 5, 2006 | 08:45 AM
SwampGas's Avatar
/etc/car
Originally Posted by Rpappi
that isnt a bad run
Figured the ballast would blow up first....everytime you unlock the car, the lights flip on...then off...then on again when I start it.
Old Sep 5, 2006 | 09:05 AM
MikePA's Avatar
The headlights do not flash, only the parking lights, side marker lights and the taillights, according to the Owner's Manual.
Old Sep 5, 2006 | 09:45 AM
fla-tls's Avatar
On the way!
No - the headlights will flash when unlocking the doors with the remote if you leave them in the on position.
In this case manual = wrong.
Old Sep 5, 2006 | 10:02 AM
MikePA's Avatar
Why would anyone do this?
I can see you have not read your manual either. Page 62 mentions this.
Old Sep 5, 2006 | 10:12 AM
georgy_d28's Avatar
OK my headlights do NOT flash when i leave the lights in the "on" position nor have they ever in the 5 or so years that i have had the car or in the two before when my parents owned the car either its only the parking lights that flash... the owners manual is NOT wrong
Old Sep 5, 2006 | 10:16 AM
fla-tls's Avatar
On the way!
Mine definitely flash when left on. I found it out on accident...
Old Sep 5, 2006 | 10:35 AM
SwampGas's Avatar
/etc/car
I didn't say they flash. If you leave your headlights on all the time (like I do), then they'll turn on when you unlock the door and stay on for a few seconds (I suppose they stay on for the timeout period when the ignition is off). When you start the car, they'll turn on again...and obviously stay on.
Old Sep 7, 2006 | 02:44 AM
03CoupeV6's Avatar
If you leave it in the "on" position:
The headlights will come on when you press unlock on the remote and stay on for 15 seconds. If you do not open the driver's door, they will turn off at that time. They come back on when you open the door. It is bad for the HIDs to do that, I strongly recommend against it.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
