Dent Questi0n!
Old Apr 28, 2001 | 08:27 PM
Post Dent Questi0n!
Do professionals use some sorts of suckion cup to suck out dents??????
By the way, its for dents that can't be reached in and behind the dent.
thanx
ATTENTION ONTARIO TL-ers: where should I take my TL to??? name and numbers please. thanx
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by AcuraJoe on April 28, 2001 @ ]</font>
Old Apr 28, 2001 | 08:45 PM
adamyankee's Avatar
Post
If its not near any structural beams they use suction cups or if they can get to it easily, they'll go in behind it to push it out.
In severe instances, they actually use a drill and make several holes where they can get in and pry the dent out. Then it has to be wet-sanded and repainted. They usually will take the whole piece to do it.
1999 Firepepper Red
Under Body Kit/Rear Wing Spoiler/26 Piece Wood Grain Console/BurlWood Shift Knob/30% Smoke Tint/Comptech Sways & Springs/02 Tails/Altstadt I's on order
More Pics
Moderator Acura-TL.com Tires/Wheels Forum
Old Apr 28, 2001 | 08:49 PM
doopstr's Avatar
Post
I remember in highschool a friend of mine "fixed" his dented door with one of those dent pullers. He basically drilled holes (lots of them) into the door and pulled! He put so much bondo in the door afterwards, the door must have weighed twice as much. Owell there's highschool kids for you
Old Apr 28, 2001 | 10:18 PM
Guest
Guest
Posts: n/a
Post
we use a device called the unispotter u
basically weld a small nail size pin into
the dent and then use a dent puller which
tightens on the pin then u pull the dent
out.after u use a bit of spot putty to fill
the remains then primer after paint,i own a
autobody shop north of toronto,u can call
me if u have any questions
(905)881-0220 ask for mike
Old Apr 28, 2001 | 11:31 PM
[VTEC]TL's Avatar
RWD convert
Post
What about paintless dent removals? How do those work?
Y2K Satin Silver/Ebony 3.2TL
AEM ShortRam intake | Magnaflow quad exhaust | Ground Control coilovers | BOSCH platinum+4 plugs | Blitz coolant pressure riser | Factory Wing | Mesh grill | Body color door handles | Lighting:Polarg M12 sidemarkers/Opti-Blue Xenon HighBeams/Eurolite 168 Xenonbulbs/Minimax Xenon dome/Hiper Strobes/Varad hyperblue LED scanner | 20%/35% Llumar Platinum tint | Räzo Shifter and Alloy pedals | 2 Rockford 10" XLC subs pushed by Boss Audio CLR60 amp | Escort Passport 7500
Factory underbody kit and wheel locks shipped. Arriving on 4/30
Old Apr 28, 2001 | 11:40 PM
TLBaller's Avatar
Post
Yeah, they use them suction(sp?) cups if its a neatly shaped dent but if its REALLY bad, they make holes in that particular area and pull it out. They have to pull it out with a precise force to make it even....like a brand new car. then they sand it down...bondo it up...and paint it. it should look just like new!
Old Apr 29, 2001 | 03:50 AM
Guest
Guest
Posts: n/a
Post
Check out:
www.dentwizard.com
Old Apr 29, 2001 | 06:06 AM
UHEARDME's Avatar
Post
The paintless dent removal, for minor parking lot dings, works great. I had always doubted it until I tried it. Can not tell where they ever were now!
Old Apr 29, 2001 | 06:33 AM
Devil's Advocate's Avatar
Post
How does it work? Can you elabortate? Is that something you can do yourself? DA
Old Apr 29, 2001 | 06:40 AM
Post
Oops, my bad..just saw the Dent Wizard link... what is the cost of getting out, say a small parking lot ding on the door? anyone know? DA
Old Apr 29, 2001 | 09:25 AM
Post
I got a DIN! right above the rear wheel. Can they use suction cup to suck the ding out?? If they can't I guess i have to live with it cuz I refuse DRILLING!
Old Apr 29, 2001 | 02:29 PM
UHEARDME's Avatar
Post
[QUOTE]Originally posted by Devil's Advocate:
[B] How does it work? Can you elabortate? Is that something you can do yourself? DA
They essentially push the ding out from the inside of the body panel. They have an array of thin metal tools with different ends on them that they get down in there (on doors they slide in between the window and door). Cost is anywhere from $30-$50 per panel (at least here in Florida).
Old Apr 29, 2001 | 07:30 PM
bdimc2001's Avatar
Talking
if Anyone is in the NYC/NJ/PA/CT tri-state area, Dent Wizard will be at the Park Ave. Acura meet. Read more about in the TL-Meets forum.
Old Apr 30, 2001 | 06:11 PM
Pimpin_TL's Avatar
Post
yeah yeah but what about paintless dent removal for a dent on the side line of our car?
Old Apr 30, 2001 | 06:28 PM
Post
The cost is around $80-$95. Some dealer actually can call those guy for you. In S. California, there is one in Irvine. It does great job.
2002 Acura TL Type S
Nighthawk Black Pearl
Parchment Leather
Old Apr 30, 2001 | 06:29 PM
Post
This is the website. http://www.paintlessdentremoval.com/
Parchment Leather
TLDude876
Dec 28, 2016 03:18 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
mugen_kid
Nov 13, 2015 10:38 PM
asahrts
Sep 4, 2015 05:55 PM
excremanCL
Wash & Wax
Mar 1, 2003 09:57 AM
