DEC 2, 2011 - Air bag recall - NEW
uʍop ǝpısdn ǝdʎʇ uɐɔ ı
Honda still has not accounted for a defective batch of parts.
This is about the third recall.
new recall details:
http://www.autoblog.com/2011/12/02/h...for-640-airba/
new recall details:
we have been expecting an expanded vin list,,they already did that twice,,,
Everyone ck in with acura care or your dealer service dept can run the vin
or self serve types- look up list online and compare to your cars numbers
the inflator prob is worse than I thought,,not just causing severe injury due to excess speed,
It has (guessing based on there is a recall) actually exploded and broken the bag itself !
possible results: death to driver!!!
I've always said airbags are dangerous because they break collarbones and burn your face.
Learn to drive and avoid their use
Now THIS!! the airbag itself will cause more damage to you than the actual crash,,,greaaaaat
makes me long for the cars of old, when steel met steel = everyone shook hands and walked away
webmastir (12-05-2011)
6G TLX-S
Looks like the 2002 TL's are no longer affected by this new recall, since my ex-2002 already had the airbag replaced twice in the previous two recalls.
recall: its not the bag = the inflator mechanism is deploying the bag at excess speed
which CAN rupture the bag
so the fix is a new inflator part
Even if `fixed` before- we all know what that means = may be a new part again
my point on airbags are dangerous-- was actually to encourage people to attend a few track day/high performance school days on a real race track- with a pro racer as your coach
End result is the abilty to spot problems ahead.. and how to drive around the scene of the crash- rather than plow into it
Plus you get to drive the TL at full throttle to max late braking points- correct turn-in to the apex- maybe some trail braking to stabilize it then back on the gas- full throttle again,,a major learning experience for 200$
my friend `the ER Doctor` says more injuries occur from the actual bag deployment,
the gas the talcum powder the impact to face and chest.. on smaller people especially!
all that = do what you can to never need the experience~
Not crashing the car is certainly the best idea. However in the event that it does happen, and lets face it, it does happen an airbag is a handy thing to have. An ER doctors anecdotal evidence aside, airbags have saved far more lives than they have taken.
Back on topic, How long does it take to have the work done? which airbags are they working on, the drivers side front, passenger front, or the side impact as well? Just curious, I have not had mine done yet and am wondering how long it takes and how involved the process is.
dont you get a loaner for the day?
if loaner is available..better chances of that tues wed thursday
Ask when making appointment, driver age minimums may apply
Its not very long actual working time, but the tech has to be trained and certified in the repair, so they have to work in time between other jobs,
or more likely = have one guy doing these all day long
if my understand is complete and correct, its the steering wheel inflator mechanism
replaced with unit of correct speed
does not remove or mess with the airbag itself during the repair
I remember reading the guys who work on anything airbag related carry tons of insurance...
I'm not in the recall according to Acura.ca
@kqxqx : Register at owners.acura.com.
Talk to service department of your local dealership. They will lookup your VIN to find if your car is covered in this or not, and then you can take an appointment with them if needed.
AZ Community Team
Received 7,771 Likes
This recall is basically expanded to inspection of ALL vehicles with this part. Something like 273,000 Acura's and over 600,000 Acura/Honda vehicles.
The current TSB (from 12/8/11) list no VIN range. It says the car must be checked via some Acura/Honda system (InVIN or something). TSB 09-033, revised 12/8/11.
http://techinfo.honda.com/rjanisis/pubs/SB/B09-033.pdf
Additional documentation avialable via the NHSTA here: http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
After you get the seach results choose "Document Search" for a (long) list of avialable documents regarding this recall.
Service Bulletin
December 8, 2011
09-033
Applies To: 2003 3.2CL – Check the iN VIN status for eligibility
2002–03 3.2TL – Check the iN VIN status for eligibility
December 8, 2011
09-033
So we don't need to check VIN coverage and all that. and can directly go take an appointment with dealer n get it checked?
AZ Community Team
The way I read it was, call a dealer and have them run the VIN in their system to determine if they need to inspect your car.
That's what I did and they said, "Yes, bring it in." However, I think a LOT of people are going to get that answer.
Of course, you could just "stop in" or make an appointment if that's more convenient than a quick phone call.
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
AZ Community Team
Go here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Follow Ron A's instructions, then try the link again:
IMPORTANT NOTICE-We seem to be back in business 14Sep11
UPDATED 14 September 2011
THE INSTRUCTIONS HAVE BEEN CHANGED AND SIMPLIFIED
We have regained our access. Follow these instructions. Exactly!
1. Open this link .
2. Open any one of the listings.
3. You can now open the below listed links.
Many thanks to TSXV6Guy for sharing this method with us.
1. Open this link .
thelastaspec (12-21-2011)
Not exactly.
I think i read something in car and driver too.
Maybe for dealerships doing recalls/replacements where the whole process is detailed and engineered to the extreme its not an issue.
I've always been curious after hearing about it, interesting that its different for you.
-or-
maybe up here in BC with our government run insurance agency they enforce rules like what i heard.
edit: fyi: in BC we only have one insurance company - its run by the government
we have these things called "crown corporations" - its a company, ran like a business, but owned by the monarch/gov.
-or-
im wrong :P
Go here: https://acurazine.com/forums/showthread.php?t=613659
Accessing Honda TechNet wasn't working for me lately and following what you posted works again!
Recall experience
So I just got back from my dealership to have this recall addressed. I was notified via the mail that my car was affected by this recall. I called to schedule an appt. with the dealership last week. They checked their system, and my car indeed needs the replacement. I went today for my appt. and after an hour of waiting, they tell me they didn't have the part! I am extremely pissed about this because if they confirmed last week I needed the replacement, why did they not have the part on hand for the appt. This is defintely my last Acura.
Biggie_B
02-26-2017 11:14 AM
rcs86
08-02-2016 06:52 PM
