debadging help
Old Aug 18, 2001 | 10:06 PM
tlacura's Avatar
debadging help
i dental flossed off the ACURA emblem on the back (the lettering).
After i flossed it, i used a hairdryer and removed as much of the glue that i could. However, i still have glue that is stuck on hard. I try to rub it off with my fingers, but the glue is smooth and kinda sticky. Is there anything you guys could recommend to get rid of the remaining glue? i'm pretty stuck here.
Old Aug 18, 2001 | 10:19 PM
AzNTL's Avatar
Keep rubbing man.. rub with the blow dryer on it
Old Aug 18, 2001 | 10:22 PM
Wampum's Avatar
Adhesive remover
I just removed the emblems today and to get the glue off I used a Gum & Adhesive Remover. The one I used it made by Kleen-Strip.
Worked pretty good with a little emblow grease.
Old Aug 18, 2001 | 10:26 PM
Longhorn TL's Avatar
I used Meguiar's Bug and Tar Remover and it worked like a charm. My friend used rubbing alcohol and it worked as well. Make sure to clean, polish, and wax the area pretty soon after you are done with it to protect the paint. Good luck.
-Burt
Old Aug 19, 2001 | 01:14 AM
wakkolio's Avatar
If you have a bottle of WD-40 laying around you can use that.
Old Aug 19, 2001 | 07:56 AM
teflon's Avatar
Use the Goo-gone. Product found in any craft store. Doesn't harm the finish.
I still had some glue, which I removed with some Detailing clay.
Haven't tried the WD-40, but I heard it works. You just have to clean it off throughly.
TLDude876
Dec 28, 2016 03:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
HOWELLiNC
3G TL Photograph Gallery
Sep 17, 2015 10:04 PM
buhhbuhh
Jul 27, 2007 09:58 AM
