Damn egr is back
Old Apr 19, 2005 | 06:25 PM
crash894's Avatar
Damn egr is back
does anyone have the part numbers to replace the valve al together ive cleaned it out 2x now and it goes away for about 3-4 months but it always comes back
Old Apr 20, 2005 | 09:06 AM
fsttyms1's Avatar
have you pulled the intake off to clean the ports or just spray in carb cleaner?
Old Apr 20, 2005 | 03:05 PM
Pure Adrenaline's Avatar
Dragging knees in
Is it the valve, or the ports? If it's clogged ports, replacing the valve won't help.
Old Apr 20, 2005 | 03:12 PM
PeteTLS's Avatar
Been trying all day to find the @#%$% site where I could look up the parts, since I'll be needing it myself soon....
18011-P8C-A00 for the valve
18715-PB2-000 for the gasket
Old Apr 20, 2005 | 05:57 PM
1st timer's Avatar
UB6IB9
what problems does a faulty egr cause?
Old Apr 20, 2005 | 06:21 PM
03CoupeV6's Avatar
05 C230K & 09 135i 6MT
Stalling? Surging? I think it depends. My best friend's Camry has had OBDII code P0104 EGR Flow Insufficient for 3 years with the CEL and the car performs no different.
Old Apr 20, 2005 | 06:53 PM
Dragging knees in
I bet his gas mileage went down a bit.
Old Apr 20, 2005 | 08:33 PM
03CoupeV6's Avatar
I don't know about that. The Camry is 5S-FE four-cylinder and gets 450-500 miles to the tank consistently. It put my old F23A Accord to shame in terms of gas mileage, and the Accord was in perfect condition.
Old Apr 21, 2005 | 08:46 AM
fsttyms1's Avatar
gas mileage typically goes down with a bad egr (if stuck open) rough idle (really rough if its stuck wide open) worse emissions. if its just a insuficant egr flow nothing will really happen since the exhaust has no where to flow, but can cause damage to a egr that is in other wise good condition
Old Apr 22, 2005 | 10:22 AM
ricebox's Avatar
I would recommend the BG egr cleaning service, that Sh*t rocks!
Old Apr 22, 2005 | 01:38 PM
1st timer's Avatar
UB6IB9
is there a DIY?
Old Apr 25, 2005 | 04:57 PM
ssaxman's Avatar
I have the same problem - took it to acura (twice) and it tuned out to be the pvc valve. I had installed an aftermarket valve which caused problems.
The car would not start when it was hot. Make sure you get an acura pvc valve!
Old Apr 25, 2005 | 06:13 PM
whatwasthat's Avatar
i have a purlator pcv valve bought that when i bought my cabin air filter. is that acura approved?
Old Apr 25, 2005 | 09:09 PM
fsttyms1's Avatar
the pcv valve isnt causing the problem, you need to take the intake off and clean the small ports out. if you continue to have the problem id recomend the egr kit thats supposed to resolve teh problem (for like 480.00$$)
rockyboy
Aug 4, 2024 10:35 AM
ibGTV
Sep 28, 2015 03:40 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
carz0159
Sep 20, 2015 06:11 PM
d.lim
Sep 15, 2015 08:54 PM
