cylinders 1 & 5 misfire, spark plugs related?
'99 Acura 3.2TL
hey guys!
my check engine light had been going on and off randomly for the last month or so, but yesterday night it came on and wont go off.
i checked the code(s) and i got 71 & 75. cylinder 1 and 5 misfire..
does that mean my spark plugs are no good?
or is it something else??
thanks!
@cUr@-TL
thanks!
@cUr@-TL
Retired MOD
1 Post
Originally Posted by @cUr@-TL
hey guys!
thanks!
@cUr@-TL
thanks!
@cUr@-TL
Then again a lot of things could cause missfires. It could also be your coils and or spark plugs.
Try changing your sparkplugs first.....aftermarket like NGK iridium. I got them pretty cheap on ebay.
'99 Acura 3.2TL
Originally Posted by Bitium
Does your temp gauge ocassionally go up and down??? this is an easy way to know if your head gasket are leaking. If they are they could couse missfired.
the temperature is always the same.
btw i have bosch platinum +4 plugs.
@cUr@-TL
What your problem is?
check timing and also the camshaft, although I doubt the camshaft will cause only two to misfire... check sparks plugs and also check you distribution rotor and make sure all connection are secure.... I had my connection loose on my civic and that caused me to misfire because the signal to ignite was sent delayed.... Good Luck and keep us informed...
Retired MOD
1 Post
@cUr@-TL
@cUr@-TL
The ECU codes won't tell you much other than missfires, been there it sucks.
'99 Acura 3.2TL
last week i set up an appointment on monday at my dealer to get the code but i found a way to do it myself on acura-cl.com so i did it.. now i'll still go at the dealer and ask what can cause a misfire.. but it's prolly the spark plugs.. hopefully..
@cUr@-TL
@cUr@-TL
Retired MOD
1 Post
@cUr@-TL
@cUr@-TL
http://www.babcox.com/editorial/ic/ic109856.htm
From the article:
"Loss of compression means the cylinder loses most of its air/fuel mixture before it can be ignited. The most likely causes here are a leaky (burned) exhaust valve or a blown head gasket. If two adjacent cylinders are misfiring, it's likely the head gasket between them has failed. Also, if an engine is overheating or losing coolant, it's likely the head gasket is the culprit. "
'99 Acura 3.2TL
well i hope the problem is the spark plug... i'll go to the dealer just to see what they'll tell me.. then im gonna go buy some NGK Iridium plugs and i'll see.. man i dont feel like replacing my plugs, it's a pain in the a$$!!!
@cUr@-TL
@cUr@-TL
Team INSPIRE Canada
i had the same prob! dealer told me it was the spark plugs and wanted to charge me $30/cdn a plug for NGK platnum. I went ahead with Bosch +4's and it's only happened twice since the change. I really doubt our engines like these +4's cuz i've had bad idling at stops which immediatly fixes itself. the real downside is my engine's died on me every so often cuz of the low idling!
MIGHT WANNA CHANGE YOUR MIND ABOUT THE BOSCH's, i'm also going iridium!
i would say its more than likely the plugs or the coils. but most likely the plugs. get rid of the bosch and pun in a set of iridiums (ngk, or denso)
'99 Acura 3.2TL
well guys the light turned off by itself today.. but im still gonna replace the plugs and i'll tell you how it goes!
on a side note, my dealer charged me like 25$ to fix my sunroof squeak.. it took like 15mins... and like always, they just put some silicon tape around the seal.. what a rip off..
@cUr@-TL
@cUr@-TL
I had the same problem with the Bosch Plat+4 plugs so I replaced them with NGK Iridium ones and its been fine ever since. Also Bosch has an unconditional full cost replacement warranty, download the pdf instructions and certificate from the web site, and you need your receipt. I submitted a claim several weeks back and awaiting a check. I got the NGK's off ebay for cheap$ so its break even and the Bosch plugs are history. It's my opinion and I've seen this posted several times that Bosch Plat+4 and Acura TL do not mix.
Paul
Paul
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
