Cutting H&R sport springs?
I'm thinking about cutting my front side H&R Sport springs. Is there anyone that has done this and can tell me how much cutting of the spring would drop it about half an inch. Im thinking of cutting it maybe half a coil. Help please!
Why would you wanna do that? get the H&R Race springs, they are about 1/2 lower then the H&R Sports. I hear really bad things about cutting springs...this is definitely a NO NO. This goes back to the early 90's...when alot of people used to do this and they would be made fun of...b/c it just really messes up the suspension I guess...can someone who knows the techicals explain why cutting springs are no good? thanks..
The springs are designed to have a specific amount of progressive resistance as it is compressed. It is a precisely designed piece of steel. When you cut part of the springs, even if you try your best to cut all the springs uniformly, you will invariably get differences in your resulting springs. Your new spring rates will be downright unpredictable. One side of your car is likely to have a higher spring rate than the other. Resistance may not be linear anymore. You increase the likelihood of losing control of your car and sliding into a ditch. In short, your suspension will be all jacked up.
Still want to cut your springs?
Originally posted by ElegantTL
in lamens term....you'll bounce like a low rider and you will bend the frame of your car. :p
Jon Lerd
Originally posted by asiankidd
Not entirely true..... the springs you have stock are alot softer than the h&r's here is then equation for springs....W=K * D where W=weight K is spring constant and D is distance travel in feet...(thanks physics 131) basically in a nut shell...the lower you drop...the higher the spring constant will have to be....having h&r (aftermarket) the constant is already respectable compared to stock...but bottem line...it wont be perfect..but you be able to live with it....if your only dropping it by .5....half a coil sounds too much too me...but keep experimenting i guess....hope that helps...
Jon Lerd
Jon Lerd
All theory aside, I know empirical experience, and I know that people who cut their springs often get a harsh ride and poor handling as a result. Most people get aftermarket springs to improve handling, if you cut them, you will be neglecting this purpose. The unpredictable outcome of the cut springs will likely increase your chances of loosing control of your car and getting into an accident. Is this something that a TL owner (or any car owner) would want?
d*mn you two!! hahah!!! I dont' understand crap! :p
Man, just don't cut your springs, you'll regret, i rather get new springs.
I saw this brand new Subaru WRX, all fixed up, at my friends shop, and they raise the car to install the Injen intake, and I looked at the springs... CUT!!!!!!! Man...that sh#t only have 1 1/2-2 coils left on that crap. He has money for rims, kit, paint this, paint that, and can't afford a decent set of performance springs for this supercar? IMO..ghetto way..and trying to cut corners...hehe.....
but your reason is different. but I still sell it and get new springs.
Originally posted by bebber
Yes, an aftermarket lowering spring should have a higher spring constant than the stock spring. However, do understand that when you cut a spring by one coil or half a coil or whatever, you will get different resulting spring constants each time you do it. It's not as if each coil of the spring has a certain amount of linear resistance. The entire springs is machined to work as a whole unit. By the way, I'm not sure if the generic spring equation for a uniform damped spring is applicable to car springs which are progressive springs. There's probably more than just a single variable to model the behavior of the progressive springs. Asiankidd, You went to Troy High right? Did you have Mr. Wahl for Physics? He's a goofy teach.
Jon Lerd
Yeah, I had Mr. Wahl too. That guy is scary. I am like majorly traumatized by him. I was hoping that he would have mercy on the human race and choose not to reproduce, but alas he has.
As for the springs. You mention taking the derivative of the coil thickness, but you didn't specify with respect to what variable. You always take derivatives, with respect to another value. A derivative is after all the instantaneous rate of change in one variable with respect to another variable. Certainly, spring length is not the only factor that determines the spring constant. In any spring though, it's an approximation to say that each coil contributes an identical amount of force as any other coil. In reality, some coils are "softer" and some are "harder" than the other coils within the same spring. This doesn't really matter about the individual coils for normal usage, because the spring rate of the entire spring is what counts. That's why everyone is saying that cutting the spring will yield an unpredictable resultant spring rate.
Jon Lerd
why waste time and money to cut springs? you just spent 30k on a nice car. If you are going to lower it more and stuff do it right. Don't cheapen your car by cutting the springs. just my thought though.
Buy A'pexi coilovers...and you can lower it to the exact height that suits your tastes....simple. Eat the cost of the H&R and sell it to some deserving board member...and buy the A'pexi....I have them..and I can lower and raise as I please....
Hey Moomaster..how's the ride on the APEXi coilovers??? want to get a nice set of coilovers...but I don't know which one...because I dont' want to lose all the luxuries of a comfy ride. Did you get the World Sport? or N1?
emailnatec
29
09-28-2018 05:27 PM
07-16-2017 08:33 AM
MrHeeltoe
09-29-2015 11:43 PM
MrHeeltoe
09-28-2015 06:43 PM
