Custom Painted Engine Cover + Calipers
Old Aug 1, 2004 | 11:54 PM
brizzle's Avatar
R.I.P Red-CL
Has anyone had their engine cover custom painted? If so, what kind of paint. Also, can the OEM calipers be painted and what kind of paint should be used for it?
Old Aug 1, 2004 | 11:56 PM
NYZGREATST's Avatar
Sig Rho's Finest
i wanna paint it myself. is it hard to do?!?! sorry to piggyback on you thread man
Old Aug 2, 2004 | 12:01 AM
brizzle's Avatar
R.I.P Red-CL
No that's alright tpatel. That's what I meant also. I'm looking to do the above work myself that's why I asked what kind of paint was used. I'm hoping to see some pics in this thread for some inspiration!!!
Old Aug 2, 2004 | 12:02 AM
indoMFP's Avatar
What your problem is?
do a search for the calipers here, lots of folks have done it, I am going to do it, as soon as it stops raining here.... the hard part is just jacking the car, removing the wheels and covering the tires so that no overspray occurs.... other than that it should be pretty easy... there is a specific paint that is to be used...
The engine cover, I do not know about...
Old Aug 2, 2004 | 12:03 AM
indoMFP's Avatar
go to the gallery, hella lot of pics there....
Old Aug 2, 2004 | 12:09 AM
brizzle's Avatar
R.I.P Red-CL
thanks, indomfp. I saw one that I did like and that was one of a carbon fiber engine cover. That was sick.
Old Aug 2, 2004 | 12:22 AM
optiq's Avatar
Old Aug 2, 2004 | 12:33 AM
brizzle's Avatar
R.I.P Red-CL
Nice look optiq, what kind of paint was used? How long have you had yours painted?
Old Aug 2, 2004 | 02:02 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
my calipers are painted, so are my engine and battery covers. the paint is holding up great and it's really not hard to do. just make sure you use high temp paint.. (even tho some said it's not required..)
if u need detailed instructions PM me!
@cUr@-TL
Old Aug 2, 2004 | 07:00 AM
brizzle's Avatar
R.I.P Red-CL
@cUr@-TL PM was sent
Old Aug 2, 2004 | 07:47 AM
NSXNEXT's Avatar
Old Aug 2, 2004 | 08:22 AM
1st timer's Avatar
UB6IB9
Originally Posted by NSXNEXT
where did you get that part in the midle that looks like it has 6 half tubes(sorry forgot the name)
Old Aug 2, 2004 | 08:28 AM
brizzle's Avatar
R.I.P Red-CL
Looks great nsxnext!! Did you do that yourself? What did you use?
Old Aug 2, 2004 | 08:35 AM
etxxz's Avatar
@ slide or die @
^^ thats the cover on the '99TL-P...its what i got. Buy some $5 high temp spray paint (200*F is enough) and a white primer to put on before the spray...OR use some regular BBQ grill paint.
Old Aug 2, 2004 | 08:43 AM
dark inspire's Avatar
El Presidente
thas what i did. Make sure u sand everything down so that the paint sticks.
Old Aug 2, 2004 | 09:03 AM
NSXNEXT's Avatar
I got it from some guy at an antique car show. It's metallic fleck paint. I've never seen it in a store.
Old Aug 2, 2004 | 09:06 AM
fsttyms1's Avatar
@cUr@-TL
high temp for the engine cover and battery cover isnt required. paint can hold up to the temps. if it got hot enough for the paint to get damaged, the plastic engine cover would also melt.
Old Aug 2, 2004 | 09:21 AM
etxxz's Avatar
@ slide or die @
better to play it safe. Plus the high temp paints have this ceramic compound that makes the metalic paints sparkle. On the calipers...DO GET HIGH TEMP...if you break a lot those calipers get over 200*F, normal paint would boil at this temps...
Old Aug 2, 2004 | 09:25 AM
whoopidoo's Avatar
2002 TL-S
I picked my Caliper Painting Kit up at Eastwood tools, and painted them over six months ago - they still look as good as the day I painted them. The kit comes with everything you need, with the exception of a steel brush that you may need if your brake dust is really heavy (I used an old toothbrush).
Here is the link (several colors to choose from):
Click Here
Here is a description from the site:
High Temperature Brake Caliper Coating - Designed for street and performance applications. Resistant to 900 degrees F and can be applied without removing or disassembling the caliper. These urethane coatings feature a 90+% gloss finish, does not fade with heat or UV exposure. Coating self-levels, prevents corrosion and attack from chemicals. Includes instruc., 2 component color - activation system, mixing jar, stir stick, degreaser and application brush. Coats @ 4 sq. ft. or 4 calipers. Made in the USA.
Only thing to note, and I am sure this goes with ALL types of caliper paint jobs - you will have to spend extra attention to keep them clean. It is definitely a pain to clean the calipers with the rims (mine are stock TLS) on the car - seems no matter how I park a portion of the rim is always in front of the caliper on one of the 4 wheels........
Hope this helps.
Old Aug 2, 2004 | 09:31 AM
SlyTLS's Avatar
Bada Bing
Here are my calipers...they're painted BMW M3 red with some metalic flake.
Here's my engine bay painted with Acura ABP paint.
For mor pics go here
Old Aug 2, 2004 | 09:33 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
as asked by brizzle, here are the instructions to paint ur engine/battery cover and calipers:
1. sand down every part you wanna paint, make sure they are free of dust/rust.
2. you can apply a coat of primer but it is not necessery.
3. apply like 3 light coats of paint and let each coat dry before applying the next one.
4. if you want a glossy look for the engine/battery covers, you can add one or more coats of clear.
5. for the brakes, i suggest you put a layer of clear coat cuz it will make cleaning much easier and the paint will last longer.
i think you should use high temp paint at least for the calipers for the reason that etxxz stated.
here's what my calipers looks like:
@cUr@-TL
Old Aug 2, 2004 | 09:50 AM
etxxz's Avatar
@ slide or die @
Here's the paint i was talking about with the ceramic compound...its called Ceramic Enamel high temp or something like it...its a spray, great.
Old Aug 2, 2004 | 10:38 AM
brizzle's Avatar
R.I.P Red-CL
How do you know when you're done sanding. Do you just wait til it's to your liking?
Old Aug 2, 2004 | 10:49 AM
@cUr@-TL's Avatar
'99 Acura 3.2TL
you're done when the part is really smooth and even.
@cUr@-TL
Old Aug 12, 2004 | 07:56 PM
JAREKsTLS's Avatar
@cUr@-TL
What number of sanding paper?
Old Aug 12, 2004 | 09:10 PM
fsttyms1's Avatar
not true! i have used it on my calipers for years with out that happening. ive had my rotors glowing red durring track days and the paint was just fine. paint (when the surface is preped right) can handle alot of temp
Feb 25, 2020 09:57 AM
merc009
Oct 3, 2015 12:59 AM
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
