Cusco Underbody Brace
Old 01-17-2010, 02:17 PM
  #41
B A N N E D
friesm2000's Avatar
Originally Posted by Ep3moschini
I can fab one up for less than $40.00 in materials I should build them and flip them lol
plus labour costs if a shop did it (and profit for you)
but yeah material costs would not be the problem, but if you made a solid one without pivots , i proably be willing to buy one off you
only problem on here would be is you have to become a vendor then, which would cost you money then
Old 01-17-2010, 02:27 PM
  #42
wham bam thank you ma'am
Rajca's Avatar
too bad ull get banned if u try to sell ur products here with out being a vendor. Ron is really hard with the black market rules
Old 01-17-2010, 03:00 PM
  #43
Like a BOSS
Ep3moschini's Avatar
im not marketing anything nor am I willing to make and sell a product.
I was just stating I "could" make it
Old 01-17-2010, 03:13 PM
  #44
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Im gettin a cusco brace since its only 90 bucks..
Old 01-18-2010, 12:30 AM
  #45
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
good decision- in a week you will be back raving about how much 90 bucks improves the car and everyone should have this
tip- the bolts the bar attaches to are on tight --as in a 4 foot long pipe over the handle of a 1/2 drive breaker bar- NOT a ratchet- a breaker bar
And a buddy to push that or leg it as you keep the socket on the bolt
Make sure they go back on just as tight as you can humanly get them, then you tighten the crossbar adjuster bolts and its on
If your car is lowered -you should be crossing steep things at an angle already- this will reinforce that technique~
Call marcus or however the `in stock check` is- make sure he has one today
they get a shipment then its gone quick-
Read his signature on his threads in black market- there is a discount code there- was azinerocks but may have changed
you should see the tsx bars list!- about 10 they can add to the structure to make it nearly race car stiff, we are lucky to get 2. Gen 3 didnt get any from japan because its not sold in japan but the gen2 is
Old 06-30-2010, 01:33 AM
  #46
Ramsrt500's Avatar
Bump!
^ +1 I put one on about a month ago. People told me you wont feel anything but as soon as I took a few of the same on-ramps and hard corners the car felt great. Quick lane changes are nice also.
Even tho my brace was FREE!! (thanks Marcus!) its well worth the money
Old 06-30-2010, 06:19 AM
  #47
01tl4tl's Avatar
I dont know who told you that you wont feel anything!!
Unless what they meant was no more feeling of opposite roll entering corners
or no feeling of a flimsy beer can for a frame while making quick lane change and back manuevers
How are those E3 plugs doing in the TL? pulled one for inspection? center electrode wear? color of side electrode??
gas mileage differance?
Old 06-30-2010, 11:32 AM
  #48
Rejckt's Avatar
shud ask heeltoe to do a groupbuy
Old 06-30-2010, 12:17 PM
  #49
MechEng
03tLsNBP's Avatar
^+1
Old 06-30-2010, 12:40 PM
  #50
I got the Shifts
phee's Avatar
nope, it will not change anything from being solid or flexible
it flexes but it doesnt stretch. so it keeps the ends of the chassis closer to each other in essence. you get less lateral stretching during turns and it causes a consistent movement on both sides. a sway bar flexes at the joints as well but it ties the sides of the chassis to each other.
same effect except and a lower point on the car which will cause an even stiffer effect during cornering while in the throttle
Old 06-30-2010, 01:34 PM
  #51
Tosh1's Avatar
Anyone have a pictures on a lowered car to see how low it actually sits... Just worried it getting ripped off on a big bump... lowered pretty good so not sure if its worth it on a really low car.
Old 06-30-2010, 03:08 PM
  #52
B A N N E D
friesm2000's Avatar
LMFAO, but anyways look at Rajca's build thread, he has one on, and ripped it off a couple of times
Old 06-30-2010, 03:18 PM
  #53
bringin lead
FirePR2002's Avatar
i'm lowered 2 inches in the front and 1 3/4 in the rear. my brace is about the height of a deck of cards from the ground.
Old 06-30-2010, 03:43 PM
  #54
Avant Garde Wheels
jjashaa's Avatar
Originally Posted by jjashaa
jk, i found it..
http://i42.photobucket.com/albums/e3...1122081156.jpg
mine got all beaten up.. lol
lol....
another pic
Old 06-30-2010, 06:08 PM
  #55
Rajca's Avatar
ill let the pics explain
cusco bar and custom bar underneath
custom bar, cusco mounts. hit a ditch. destroyed the mounts
my other underbrace bar that i made was solid from one bolt hole to the other. 3/16" round bar.
hit some rail road tracks, few ditched and some uneven streets. bar is fine. bolt holes on subframe are bent back bc of it. so i took it out. im done dealing with it.
remember, my subframe is lowed 1 additional inch.
Old 06-30-2010, 06:45 PM
  #56
Ramsrt500's Avatar
It was some nob back when I first got the car.
The plugs are good, I changed the oil & filter, deleted the mid-muffler, washed my intake filter and got new tires at the same time as the install of the plugs so my gas mileage did go up but I cant say it was from the plugs. I havent pulled one yet but they should be ok. Have you heard anything bad about the E3's
Old 06-30-2010, 06:49 PM
  #57
Ramsrt500's Avatar
Im still in 4x4 mode so im not that worried about the brace.
Old 06-30-2010, 08:41 PM
  #58
01tl4tl's Avatar
If you drive a lowered car- learn to drive a lowered car!!
Stock height will have no clearance issues
Its not that tough to avoid or conquer the steep driveways and potholes- raised manhole covers during repaving etc
approach steep angles at a directional angle, one front wheel at a time over the bump or thru the dip should keep you safe
Im set at normal low for Teins on 18s -01TL,
and the lower bar does take some minor scratches and hits- but it saves my cat convertor from damage (which sadly must remain- not into installing every 2 years for inspection)
Old 06-30-2010, 09:12 PM
  #59
Rajca's Avatar
i know how to drive a lowered car. but if a 45lbs crane hook flies off a truck and u got no where to go, what do u ? stuff is gonna break when u hit it going 35mph
and chicago roads suck (kris already know that as he blew on of his shocks)
the custom bar was half an inch off the ground, and the tire was half an inch away from the tip of the fender
Old 07-01-2010, 05:34 AM
  #60
01tl4tl's Avatar
I wasnt poking at you raj-
rather at generic someone else' who took out a raised manhole-road was being resurfaced and had been excavated..did a number on the bar--was lucky thats all it took out!
mine has extra marks I cant explain.. and dont want to know how the wife treats it~
Just might be one of those generic type people
Old 07-02-2010, 11:31 AM
  #61
Former Sponsor
MrHeeltoe's Avatar
I'd be happy to.
Old 07-02-2010, 11:33 AM
  #62
Former Sponsor
MrHeeltoe's Avatar
This part is a performance part. As such it is not really going to function based on the height of your car. If you have a great performing suspension for the street, odds are your car is not on the ground and you won't have problems scraping this brace. If you super low, you are going to drag it, but then this part wasn't really meant for you
Old 07-02-2010, 12:46 PM
  #63
Ramsrt500's Avatar
^+1 I will neveer go that low so im not worried about the bar.
Any word on new brace/susp. mods for the UA5? I'll prob order the strut tower brace soon.
Old 07-02-2010, 01:42 PM
  #64
Avant Garde Wheels
jjashaa's Avatar
with enough people interested and have money to put a down.. possibly...
Old 07-02-2010, 01:59 PM
  #65
Ramsrt500's Avatar
I was thinking of something cheap like the lower brace. Maybe a rear lower brace?
Maybe some kind of engine brace/damper so I can stop breaking mounts!
If its only $80-$100 im sure guys would jump all over them.
Old 07-02-2010, 02:16 PM
  #66
fobstylez's Avatar
lol I have josh's old bar, bought it but never put it on. lol dude i forgot i even have, it, pm me if somebody wants it
Old 07-02-2010, 02:45 PM
  #67
Ramsrt500's Avatar
I just hit 300 post!! and it only took me two years!!
Old 07-02-2010, 03:09 PM
  #68
Rajca's Avatar
No room in the back for a rear tie bar. I've already looked with duel stock exhaust, its not happening. The exhaust would get in the way
their a thread about an engine dampner, not sure what the status on it is
Old 07-02-2010, 03:24 PM
  #69
B A N N E D
friesm2000's Avatar
, yeah, as far as status, they did a "final" fitmit, but they did not quite cut out enough of it, to go around the low side A/C port , so the updated design had to be sent back to the manufacture to be recut , so waiting on the arrival of that
btw just looked at dates, and it should actually be here , and just called and should be picking it up this coming week
Old 07-02-2010, 03:46 PM
  #70
Ramsrt500's Avatar
Weak!
Yeah the engine dampner thread looks promising.
RL780
10-19-2015 09:46 AM
lanechanger
10-13-2015 10:56 AM
lowgrowl
09-26-2015 05:18 PM
HOWELLiNC
09-18-2015 11:12 PM
09-17-2015 10:16 AM
Quick Reply: Cusco Underbody Brace
