creaking drivers seat
Old Sep 17, 2002 | 11:22 AM
Eternal TL2k3's Avatar
has anyone experienced their driver seat to be creaking? i started noticing it about 2weeks ago and then it went away for a bit. Until recently when i turned down the sound on the system, i didnt notice but the squeeking is really bad.
anyone else experience this?
Old Sep 17, 2002 | 11:27 AM
Ajay_RENAMED's Avatar
I know that in my car the Lumbar support handle rubs against the center console. Dont know whay they would design it this way. Most of the time I dont use the Lumbar support becuase the squeking drives me nuts.
Old Sep 17, 2002 | 11:30 AM
SilverUA5's Avatar
Re: creaking drivers seat
It's your seatbelt buckle. Try spraying some WD-40 around the the area, and it should go away.
Old Sep 17, 2002 | 12:01 PM
i dont think its the seatbelt buckle... the squeeking comes when i hit bumps in the road and seems to be coming from underneath the seat...
Old Sep 17, 2002 | 12:04 PM
accordv6's Avatar
I seem to have a similar problem in my AV6......kinda upsets me considering the car only has 4,000 miles on it. Looks like I'm gonna have to go to the dealership and let them fix it (or attempt to)......I hate taking my car to the dealer! Trust no one!
Old Sep 17, 2002 | 12:06 PM
paxus's Avatar
My driver seat squeaking/creaking is a result of the lumbar support handle rubbing my center console. I'm going to take my car in to the dealership to have them fix that creak while they check my water pump. New $30k cars should not squeak. They'll probably put some lubricant on the lumbar support handle that doesn't hurt the leather on the console. That's my guess though.
well im due for the waterpump recall anyways (stil havent made an appt to get that done) so i might as well go and get it all done in one shot. Maybe while im there i can pick up the Type S shift knob that was sitting in one of the cars there. Dunno what it was doing sitting in the cupholder but its mine next time i go there
Old Sep 17, 2002 | 12:12 PM
SilverUA5's Avatar
Your gonna steal the shift knob?:wow: Anyways, my squeeking noise is from the buckle and the reason I know that is whenever I hold on to it, the noise stops and yes, it only happens once in a while when I hit a bump.
Old Sep 17, 2002 | 12:17 PM
not steal per se... more like take and not return. I figure i could put it on my dads old 88civic and give him the extra 10HP from it
Old Sep 17, 2002 | 12:47 PM
NighthawkBlack's Avatar
I found the seat back plastic cover to make noise. Also I had my seat rails on drivers side changed 2 times because the seat would make noise when my weight shifted. As far as the lumbar support goes, I moved the center console over a tad to get clearence in the up position. It will always touch when down.
Old Sep 17, 2002 | 01:18 PM
JPritch's Avatar
All Hail the Chief
I've experienced the creaky driver's seat at times....but I thought it was just b/c I was fat!
Mine also sounds like it's coming from underneath/behind the seat.
Old Sep 17, 2002 | 01:22 PM
ScotTLTypeS's Avatar
I've got it too. I sprayed the seat belt buckle, but still have the creaking. It doesn't do it when I don't have my seat belt on, so now I'm thinking it might be coming from where the seat belt is anchored...
Old Sep 17, 2002 | 01:42 PM
9th Gear
Angry Creaking chair
I am having the same problem, I thought itd was something that I had under the seat, but I looked and didn't find anything.
Now I know for sure it's the freaking car itself, so now I'm totally pissed off!
And one more problem I am experiencing. My car sounds a bit like a motorcycle when in idling. It's not too loud, but it doesn't sound good to me anyway. It doesnt sound good at all.
Old Sep 17, 2002 | 02:16 PM
i never knew where the squeaks from the seat comes from, but now thanks to all u guys i have ideas as to whereabout i could locate these annoying sounds
Old Sep 17, 2002 | 04:34 PM
jdone's Avatar
There has been a tsb out on this for over two years-I don't know why the factory didn't fix the problem faster. When I told the service manager about this they fixed it first try over a year ago. If your passenger seat gets used much it will start the same thing.
Old Sep 17, 2002 | 04:41 PM
Aki's TL's Avatar
Spray a little WD40 where the seat beat connects, rub a little leather cream where the top seat and bottom seat meet.
My passenger seat used make squeeky noises - and it drove me crazy!!! Not anymore...
The other noise that drove me crazy was the middle console
I tightened the screws on the top (the part that flips up)
also put on some felt material to where the top attaches onto the middle console - so that it attaches snug
No more squeeky sounds!!
Old Sep 17, 2002 | 09:16 PM
The passenger seat on my tl-s '03 makes this rattling noise when someone seats on it and I'm doing over 65-70 mph. I guess I'll try to "tackle" it and look for a solution or fix when it becomes "unbearable"...
Old Jul 25, 2003 | 03:57 PM
I just fixed this in my 99 TL. You have to take the panel off the back of the front seat, and spray WD-40 into the metal sleeve where the spring that holds the foam clips to. My creak is gone.
Old Jul 26, 2003 | 10:57 AM
fsttyms1's Avatar
there is a tsb on the squeaky seat. it is the seat belt anchor. bring it in and they will fix it. i believe it needs like a rubber washer. or you can spray a lil dw40 down where it mounts
Old Jul 26, 2003 | 11:25 AM
Bxscig's Avatar
Recently I noticed the same thing... I dont know the hell it is and I checked under car for the front sway bar and noticed it was loose on one end... one of the bolts holding the bracket. I think it is that. I have to fix it and check it out. Car is 3 months old too.
Old Jul 26, 2003 | 12:55 PM
My creak was different from the seat belt anchor. It was coming from inside the back of the seat, especially when i leaned back. I had to remove the back panel of the seat and do something like this... but not quite because the seat is slightly different in my '99. I had to spray WD-40 into the sleeves that the spring clips into.. wish I would've taken pics.
Feb 25, 2020 09:57 AM
BoricuaTL
Apr 8, 2016 01:08 PM
cm561
Jan 27, 2016 10:17 PM
kareshi
Sep 3, 2015 03:38 PM
