Crankshaft pulley
Crankshaft pulley
I've been trying to complete my timing belt. Not an easy task for a rookie. I am to the point where I need to put the timing belt back on. However, I didn't put the crankshaft bolt back in before I removed the belt. Now the crankshaft pulley spins freely of the crankshaft. Was i supposed to put the bolt back in before removing the belt? If I align the rear and front cams...do I need to somehow align the crankshaft pulley with the camshaft pulleys before I put the new belt in? Any answers would be greatly appreciated.
https://www.oemacuraparts.com/auto-p...rankshaft-scat
Is the 'key' (#16 on the link) installed in the key way of the crankshaft when you place the TB drive pulley? That would keep it from spinning freely.
Or do I just line up the crankshaft pulley with the arrow and lock it in place with the key and the bolt and put the new belt on?
Relax and don't panic. You're doing fine.
The crank shaft will move if you didn't take out the spark plugs and the cams will move because of the valve springs. This to be expected.
The timing will be off when removing the T belt, perfect normal.
The timing will be off when removing the T belt, perfectly normal.
After putting the t belt on all you need to do is make sure all the marks are in alignment... Both cams and crank shaft pully. If they are then turn the timing bolt by hand (wrench) clock wise 5 or 6 rotations until the timing marks (TDC) are aligned again (one full 4 stroke cycle). Do not continue until you have a visual comfirmation that all the marks are in alignment a second time. Once you have visual comfirmation the second time then you're home free from there and the rest is down hill.
zeta (01-13-2018)
zeta (04-01-2018)
Per the Helm's manual:
Install the timing belt in a counterclockwise sequence starting with the drive pulley.
1 Drive pulley
2 Idler pulley
3 Front camshaft pulley
4 Water pump pulley
5 Rear camshaft pulley
6 Adjusting pulley
1 Drive pulley
2 Idler pulley
4 Water pump pulley
6 Adjusting pulley
I tried it per the helms manual with no success. Do the 2 pulleys and the tensioner need to be installed prior to installing the belt?
also...would the time belt contract in cold weather? Maybe that's a dumb question but it seems like something just isn't right....as in the belt is not long enough. The camshafts always get out of timing when I force the belt into place. I've heard there's a tool you can buy/rent to hold them in place. Are you aware of this tool?
Idler pulleys go on first, then the belt, and tensioner is last.
The belt is smaller in colder weather but not much. It's suppose to be tight.
Sounds like you already had the belt on but marks are off after doing so. So the belt fits and you already know how to install it.
What you need to do is count how many teeth it's off when the belt is on and then take it off and guesstimate by rotating the cam sprocket off timing by the the same or similar amount of teeth to compensate for the rotation of the cam sprocket once the belt is installed. Keep doing that until the marks are align. You might put more pressure on The Idler Pulley to give yourself more slack to make it a little easier.
There's no timing tool because it's all trial and error until all the marks are align.
In the Helm's, as the last step in 'Removing the TB' it states to loosen the Idler pulley bolt 5 or 6 turns, then remove the TB. If you look at the attached scan, when you get the timing belt installed, then the Helm's states to 'tighten the idler pulley bolt' to 33 lbf-ft. Therefore, if you have the Idler pulley fully installed and tightened, that may be the space difference that is restricting your placement of the new TB. Get what I'm saying?
I haven't been able to even get the new belt back on yet. In your fourth paragraph above I got confused. So, I attempted to mark the old belt at tdc and transferred those marks to the new belt. If I'm able to get the new belt on and have all the pulleys at tdc but the new belt marks are off a couple notches....would that be an issue? Or is it only critical to get all the pulleys at Tdc?
In addition to reviewing your response I plan on doing the following.
1. Loosen the idler pulley.
2. Have a friend hold the front and rear cams in place while maneuvering the new belt on
3. Using a hair dryer while belt is close in order to expand the rubber
4. Cover in gasoline and throw a match bahahaha
Thanks for your help!
I plan on starting back on this project thus Saturday. Above you said that the tensioner goes on last. Are you referring to the piece with the pin in it? If so, I tried to put that on last but it was near impossible due to lack of clearance behind the adjusting pulley.
In addition, you could put the TB in a preheated oven at its lowest setting, for about 30-45minutes (about 100F or so), before your attempted install to increase pliability.
Good Luck!
Idler pulleys go on first (leaving the idler pulley loose), then the tensioner, T belt (counter clockwise starting at the crank shaft pully), and then pull the pin off of the tensioner is last. Don't for get to tighten the loose idler pulley bolt.
Once the belt is on. It's critical that the timing marks are all in alignment. If the marks are off, then you have to keep removing and reinstalling the T belt until the all the marks are in alignment.
Don't worry about the belt's notches being off. The timing marks are what is important. When the marks are all in alignment then the belt's notches are in the right place.
I wouldn't heat up the T belt. The belt is made to with stand high heat without stretching. Think off hot summer days with the engine running. It's still keeping the engine timing under the closed hood... Not stretching. The belt will be damaged if it stretches. Just keep the belt at normal room temperature or a warm room.
So, I got the belt back on! I still need to torque down the pulleys and tensioner and release the pin. What is the "timing bolt " that you referenced above that I need to turn to rotate the cams and crankshaft? Is it any of the 3 bolts? I don't have the bolt back in the crankshaft yet so maybe I need to turn the front or rear cam bolts? Also, should I rotate as stated above before or after I pull the tensioner pin?
oh, what I did different to get the belt back on was to loosen the idler pulley and I got a friend to help me....basically we installed the belt from the crankshaft to the front cam...through water pump pulley and when we got to the rear cam there was a fine line of muscle and finesse to move the JUMPY rear cam and put the belt on. Even the marks I put on the new belt lined up!!!
Yes, after you pull the belt tensioner pin and then put the crank pully on and rotate the crank pully bolt TDC to TDC again clockwise by hand rachet to double check your timing marks again. If it's still in timing the second time then you're good to go... Button her up... Congrads!
You should replace the following...
All belts, plugs, thermostat, rad cap, air filter, all remove able idler pulleys. You will get more than your money back in MPG.
Don't forget to open the heater valve when burping the cooling system. Just fill the radiator to the top and let the car idle until the rad fan comes on twice. Then top off rad and overflow tank.
how many rotations do you make?
what plugs are there to replace? Just the dead end ones that are cracked? I found one of those.
where is the heater valve?
I will purchase a new cap thermostat and air filter.
also. I bought a radiator flushing chemical because I'm pretty sure it's rusted from having water in it. Have any of you used a radiator flushing chemical?
Not sure how many rotations but you can track the number one piston by using a screw driver through the spark plug hole.
At TDC the no. 1 piston is going to move up and down two times. First time back up is the exhaust stroke (half way). Second time back up will be the compression stroke again... That's TDC again. Now check the marks again. They all should be in alignment again.
You have to do it with the pin out because that might change the belt tension and move the pulleys around a little bit. Better safe than sorry.
The slot on the crankshaft where the woodruff key goes should be at the 12 o'clock position. There is also a mark on the crank gear right above the key slot that lines up with the arrow mark on the block at TDC. Obviously, the marks on the front and rear cam gears must also line up with their TDC marks in order for everything to be in time.
I finally finished the timing belt! I have one problem. I stripped the threads on the bracket that connects to the engine behind the timing belt covers that the engine mount connects to. I put the bolt back in with blue lok tire and I haven't driven it yet. Does anyone have a permanent solution? Please help
ifirahse
06-08-2009 04:05 PM
