Could my sway bar link cause vibration? [PICTURE]
I've had my front sway bar links replaced (along with the steering rack, upper and lower ball joints) and since then my 2003 TL has been vibrating at the steering wheel every time we get to 55mph.
I got underneath the car and checked the ball joints and the steering rack. Nothing looked abnormal. But then. this is what the driver-side sway bar link looks like: https://cimg0.ibsrv.net/gimg/acurazi...60802ddbe6.jpg This link looked bent, under pressure, as if it wanted to rip out of the boot. Do you think this is the source of the vibration? |
I am not a mechanic, but if something looks bent/rusted through, especially with the suspension/steering, replace it.
The parts aren't that expensive, go on rockauto.com, there are online discount codes, and just replace what looks like it is worn/bent/damaged. I had my 02 Accord written off because of a lower ball joint. Cheap part that can save alot of problems if you just replace it. The vibrations should be a warning to you. Not sure if you are hearing any other noises or not, but for sure, check all the suspension components, tires and steering. |
Replace it anyway.
May be axles though |
I only mention this because you said you had your front upper sway links replaced. On some models, it is possible to install the sway bar upside down which causes vibration and often rubbing on other components. It's not always easy to determine which side is up without looking at another similar vehicle.
I am keenly interested in whether the OP solved the vibration problem and what the solution was. I've got a similar vibration that sets in around 55 - 60 mph+ that's driving me CRAZY. Tires balanced and re-balanced, including road force balancing -- no improvement. Replaced all 4 struts -- still there. To my eye nothing on the front end looks worn, damaged, or loose that I can find.
I've purchased new axles and those go on next. If that doesn't solve it, I'm about out of ideas! |
Deohaven; it looks to me like the links got swapped side to side. I doubt that it would cause any vibration, but I'd take it back and get it corrected.
Originally Posted by Skeet33
(Post 16142211)
I've purchased new axles and those go on next. If that doesn't solve it, I'm about out of ideas! Although I have serious doubts anything is wrong with the tires, I'm taking it in to where I purchased them to see if they'll swap them out. With any luck, maybe with some credit from tire manufacturer. |
Have you checked for a bent rim?
Originally Posted by Iggy
(Post 16144012)
They can look perfectly normal at a glance but until you see them spinning you wouldn't know for sure. If you can get the front end of the ground and properly supported, you can start the engine, put it in gear and visually check both sides of each wheel while they are spinning.
(Post 16144074)
...start the engine, put it in gear and visually check both sides of each wheel while they are spinning.
We hand-spun the wheels and couldn't see anything on any of the rims, but the fronts would only spin slowly, of course, in neutral. I'll put it on jack stands today and try what you suggested, starting it and watching them spin, idling in Drive. Thanks! |
Finally.... SOLVED!! It ended up being the motor mounts. They were progressively getting worse, and I finally clued in when I started hearing some strange clunking noises at lower speeds. On bad low speed bumps I starting noticing kind of a "shudder" in the suspension, which ended up being the engine itself shaking around, unrestrained by its shot mounts. The suspension is actually in great shape since I replaced the struts not long ago, trying to figure this out.
The frustrating part of this whole problem is that nobody could diagnose it. The primary symptom being rhythmic vibration at speeds around 55-65 was leading everybody to think wheels, tires, or suspension. I went ahead and replaced all three motor mounts, along with both transmission mounts. Both the front and side mounts were completely trashed. The rear wasn't noticeably torn, but it was a little soggy. The transmission mounts looked OK, but I wasn't taking any chances. After 17 years in the car they had earned their retirement. Replacing the rear mount was one hell of a job. If I feel the mounts going bad again I'll jump on that front mount quick, but I probably won't do the rear one ever again if I can help it. What a relief to have this behind me! |
Out of curiosity, what brand mounts did you use?
(Post 16179833)
It still isn't quite clear to me why Beck/Arnley offers 2 different options for the front mount - both of which are listed as direct replacement parts - or what the difference is between them. I went with this one (104-2008) but there is also this other one Maybe somebody can shed some light on the difference? They feel fine. Vibrations at speed are gone, and both acceleration and shifting is back to being crisp and direct. I might be getting more vibration coming through at idle than with the OEM mounts, but it's hard to say since mine were in such bad shape. If it means they're more durable, I'd say it's well worth it. |
did you do it yourself or have a shop do it?
Originally Posted by elfnumber1
(Post 16181348)
Doing all 5 mounts like I did would have been pretty costly at any shop, but ridiculously high at the dealership. There's just no way around it - it's a time consuming job. Nothing about it is so technically difficult, there's just a lot of figuring out how to work your arms, tools, bolts, and the parts into very awkward and tight positions. I've never spent so much time hugging my engine block. In hindsight the front and side mounts don't seem so bad, but that may just be because the rear mount was so brutal. If you're considering it, read up in the DIY threads here, make sure you have the right tools (long socket extensions, breaker bar, u-joints, etc), and allow yourself enough time. When it's all said and done, a challenging but satisfying job. |
Was there a particular DIY on here that you could point to that you followed for the Rear and transmission mounts?
Originally Posted by Chojun
(Post 16182657)
chojun, sent you a PM a few weeks ago...check it? |
(Post 16182657)
Some of the step-by-step instructions won't make sense until you get into the job, and some of the bolt sequences didn't match exactly for me, but keeping a printed copy at hand was very helpful. The rear mount bracket on 1999 TL's is slightly different from 2000-2003 models, which could account for some of the differences. I never found a DIY for the transmission mounts, but you really don't need one. Do them last and they'll seem easy by comparison. A few helpful things I recall:
Ah thanks! I have that DIY bookmarked. I think what I'll do is get the front and side replaced, then do the rear, and then the trans mounts. The side mount looks super simple. The service manual literally has 3 steps for the rear mount - it's not helpful at all.
chojun, where do you live? i want to help, or you better just post pictures of the diy job. then you can help me, personally or via pictures and a write up.
(Post 16182850)
The side is the easiest. I found this DIY on the side mount: DIY: Replace side engine mount • Acura TL (LINK) Unfortunately the photos are gone, but some of the step-by-step is informative. It mentions the brake line clipped to the back of the mount, which is easy to overlook. Only tip I'd add is go ahead and unbolt and swing the cruise control module out of the way as you start. Much easier than trying to work around it. |
(Post 16182867)
I'm pretty certain I have broken mount(s) because of how I can feel the engine bouncing around inside under certain conditions. I don't think I have a vacuum leak but my idle runs a bit high so it could be a very small leak in one of the mounts. |
