Cooler air=More power
If it is true.why don't we remove the big plastic box which is just right under the air filter?then the engine will suck the frensh air just behind the bumper,not beside the hot engine anymore.I know some of you will say there is risk of dirt into the engine,but that's why we have a air filter.am i right?
they put that box there
for two reason i think,
a, if you look in the box theres passages of air ways in there so that big debris can't get sucked up...helps keep the air filter cleaner and filtering for smaller things
b, it can help preventing water getting sucked up through the intake
i also think its to silence the intake when full throttle. many would rather prefer quiet engine
removing that box may help to get more air in but then again chances of other things start to go up too....
That's the whole reason for getting a CAI (Cold Air Intake). You remove the stock airbox and the resonator from inside the fenderwell. The airfilter then goes inside the fenderwell where it can draw cooler air.
i tought gettin water in your intake means boost in hp?
Quite a few people here have already removed the resonator.
It's a free mod, no reason not to. Sound good too... just a
bit more high rpm growl. You'd have to drive into a swimming
pool to suck water though. And dirt isn't too bad because you're
still behind your inspection shield.
Retired MOD
1 Post
Re: Cooler air=More power
Injen offers a heatshield on its intake to filter out any hot air being taken in by the intake. Also, AEM offers the bypass-valve, which helps in a way of unwanted substances (water, snow, etc.) from being taken in by the intake as well.
Comptech Freak
cold air+ low humidity works best...u can feel it more livier...
my old regal has significant difference for the weather change as the 3.8liter pulls a lot stronger during cold days and on the other hand it doesn't have the off the line punch during the hot summer days...even with no A/C on...
i wouldn't want to take away that plastic box...every parts in the car is there for a reason...i don't know how it works but i wouldn't do sth that would damage my engine...
The New 3 Series Coupe
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
