convert FWD to RWD???
doubt it would be worth it - you need a drive shaft, then have to get rid of the front CV joints so the entire front end would need overhaul and there is not enough of a tunnel oin the floor and you need rear differential and gears and probably a different axle - get a used BMW or other rwd -
convert a FWD to RWD? are you kidding man...might as well convert your TL into a convertible..you might want to try Monster Garage...Jesse James might be able to do a little "conversion" on your TL
any thing is possible with the right amount of money, but why would you want to? just buy a car that is already a RWD. i.e. G35, BMW, Mercedes.ect.....
I'M Rich Beeyoch!
You can't seriously be considering this, can you? You could sell your TL and buy a G35 for less than the difference it would cost to make such a foolhardy conversion.
I'M Rich Beeyoch!
![No No](https://acurazine.com/forums/images/smilies/nono.gif)
I agree with the above get a different car...
You really want to change the way the engine sits in your car? (It's horizontal now, you going to rotate it so it's vertical?) I don't think it's possible.
Even if it was you won't have the same car as before... Just sit there and think of that bolt the mechanic left sitting on his bench as you drive off. A few miles down the road you'll figure it out.
I shoot people
I remember when I used to own a Dodge Ram truck that was only a V6 and I sooooooo very badly wanted to... somehow, drop a V8 in there, and after asking around... I realized what a dumb idea it was... it would cheaper to sell my V6 and buy a used V8 with less miles.
...and I'm no mechanic, but switching from a V6 to a V8 in a Dodge Ram truck would be less work (and money) than converting a TL from FWD to RWD.
Pusha Z
ahahahaha unless you are the biggest Second Generation TL fanatic ever, I would suggest you get the car you really wanted... ahahahahaha Im sorry I just found that hilarious. Although a chop-top honda civic si hatchback is sick looking
I'M Rich Beeyoch!
Originally posted by EddieXo
a while ago in a magazine i saw a crx rwd with a 350 block in there... that was the most american crx i have ever seen...
and probably the most illegal...probably
you cant even use the same engine you have....or the tranmision...i doubt you could find a rearend that could be easily fitted in the back....overall..its just a stupid idea..
joflewbyu2
08-18-2019 10:38 PM
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
