Cold start grinding noise
Old Feb 13, 2012 | 04:35 PM
rog2961's Avatar
Been a while since ive been on the boards. I have a bit of a problem, my cl has not been driven as much as it should be lately. One a couple occasions after the car has been sitting for a while, when i start up the car in the cold, it will have this horrible grinding noise. Regardless of if im in gear, out of gear, D, or R it will make this grinding sound. It increases with the speed of the engine. I originally thought it could be motor mounts, but the sound disappears when the car gets warm. The last two times it happened I let it warm up, shut off the car, and the sound went away. Any thoughts?
Old Feb 14, 2012 | 09:09 AM
VTEC11's Avatar
Could be an accessory belt or tensioner.
Old Feb 14, 2012 | 10:10 AM
rog2961's Avatar
I'll take a look, is there anything in particular to look for?
Old Feb 14, 2012 | 11:12 AM
victus1's Avatar
You can look for belt misalignment or wear. If you spray belt dressing or wd-40 on it and the sound changes, then you know you have a belt problem.
But see if the noise is coming from that area. It may be the belt tensioner which presses against the belt. It may be your power steering pump making the noise. There are several places which the noise can come from....timing belt, pulleys, tensioner failing, water pump.....
Old Feb 14, 2012 | 02:26 PM
rog2961's Avatar
Gives me a reason to go get a mechanics scope! Ill listen around and see if I can find out where the noise is coming from.
Old Feb 16, 2012 | 10:43 AM
RC99TL's Avatar
Sounds like normal power steering growl on start up.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
obert
Dec 14, 2015 11:36 PM
dlknight
Sep 3, 2015 07:54 PM
